User Interface
- fixed: memory garbage displayed, if current View contains only one single rig
- fixed: stomp type information sent to and reflected by some adapted foot-controllers
- added: key repeat for PAGE buttons and RIG Navigation Cross
- added: unique default owner name "Me [some-id]" instead of the generic "Me"
- changed: Effect Types "Noise Gate 2:1/4:1" instead of "Gate 2:1/4:1"
Audio
- added: new Output Source "Git / Master Left" added for S/PDIF OUTPUT
- added: new parameter Panorama in Rig Menu
- fixed: DIRECT OUT with source "Master Mono/Right" now correctly switching into SEND functionality and avoiding feedback, when any loop gets activated
- fixed: avoiding noise in combination with a few clean sounds
- fixed: avoiding crackling within first three seconds after rig load
- changed: slightly adjusted bass response during profiling increasing authenticity
- changed: reduced latency of effect Micro Pitch
- changed: reduced time to bypass Wah, if Pedal Mode set to "Bypass @ Stop/Heel/Toe"
Profile was a custom rolled one of my VHT Sig X; uses the rhythm channel without a boost first, then the lead channel with the boost when it gets heavy.
Uses the latest 2.7 firmware too.
I had the Axe FX. I then got the Kemper. I sold the Axe FX. I was happier with the tones from the Kemper and more importantly I was happier with how quick it took me to get to where I wanted to be.
Both units utterly wipe the floor with every single VST amp effect out there - and I've got them *all* and the only plugin I use these days is a freebie Sansamp Bass Driver plugin. The rest of them... I don't use them anymore.
If this means that the cab part of a profile can be removed then I'm looking forward to trying this out. Anyone know if this is backwards compatible with existing profiles? If not, then all the TAF profiles I have won't be much use :-(
All excited.
