My Bedroom Practice Set up is......
HootsmonHootsmon Frets: 15994
edited December 2014 in Guitar
2002 Les Paul STD into Barber drives/delay/reverb/ Laney VC15
when I want to keep things to myself it's a POD V2 c/w headphones
tae be or not tae be
«13
  • StevepageStevepage Frets: 3062
    Straight into the Line 6 Toneport for me. I use it for practicing and recording. If I play in the living room then it's my little Line 6 Spider III 15 thing.
  • Fender USA Big Apple strat into a Marshall SL-5.
  • jd0272jd0272 Frets: 3867
    Rarely plug in at home. If I do it's into the LC15R or one of the little novelty Marshall/Fender battery things.
  • impmannimpmann Frets: 12683
    For me an early 70s VampPower Power Baby15w combo, with a selection of pedals - but normally an EQD Dispatch Master at least.
  • I play unplugged a lot of the time, I also use a Vox DA5 and my iPhone.
  • beed84beed84 Frets: 2420
    A classical guitar.
  • Any electric guitar into laptop with S-Gear and headphones. Flat + Baby = no noise.
  • RaymondLinRaymondLin Frets: 11942
    Normally just a PRS 305 into a THR10
  • tbmtbm Frets: 585
    Whatever guitar is out - currently a Danelectro Long Horn baritone - into modded Vox AC4.
    Noise, randomness, ballistic uncertainty.
  • John_PJohn_P Frets: 2750
    Usually I have the thr10 and one of the prs plus the avalon acoustic in the living room.  All the other amps and guitars are cased up ready to grab for a gig.   Apart from a couple of marshall halfstacks in the dining room that I can't fit in the car.  Roll on the new studio build next year so I can leave everything set up ready to use.
  • Strat/Tele/RG ---> Hot Rod Deluxe (my only amp).
    But more usually:
    Strat/Tele/RG ---> Nothing. :)
  • ElxElx Frets: 412
    Guitar Rig, Amplitube or Jamup Pro and headphones...
  • I get to play my live rig in my living room :-)
  • Any of my guitars into a Marshall MG10CF, with maybe a pocket POD in between for FX.
    That's actually my main rig ;)
  • RMJRMJ Frets: 1274
    Guitar into eleven rack with headphonage
  • as i only play at home my set up is my squier vm jaguar into my vox valvetronix vt 40+ (through headphones at night).
    i like cake :-) here's my youtube channel   https://www.youtube.com/user/racefaceec90
  • SG Jr. into THR10 or pocket pod. (With a good set of headphones once the toddler is asleep!)
  • underdogunderdog Frets: 8334
    Les Paul in to either HT5 mini stack, or joyo British sound then Epi VJ or in to pocket pod.
  • Les Paul or 335 into 50 watt amp, or Bass into 300 watts, though I do make use of the volume controls!!
  • THR10 and whatever guitar of mine I fancy using. Usually the Telecaster.
