What diameter?
Two options: Bit of (say) 3mm BMSteel rod. Get red hot on gas torch flame and bash the end out to 4x4mm.
File to a 90dgr point then file "cutting" faces on either side. Start the job with a proper drill then use the bosher.
2) Get someone with welding gear to butt weld a bit of rod to the arse end of a drill bit. (I used to Silver solder bits together to make special tools)
Dave.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I use a 160mm long 3mm bit I bought from Cromwell.
I'm redoing mine when I next restring to get a few mm more depth to each hole. I'd send you a bit but I only have the one - it's sole purpose is for drilling claw holes!
I'm scared of ruining the finish though. GODDAMMIT.
