SOLD: Pair of Jackson J-80C humbucking pickups
The Shob clear out continues.
This time I've got a pair of J80-C pickups for sale. These are high-output ceramic pickups, they have 4 conductors so can be coil tapped if required. Sound wise they're similar to a Duncan JB, some may disagree by to my ears they sound similar.
One thing you should bear in mind, with the covers on they will not fit in regular pickup rings (thank you Jackson), but with the covers removed they fit OK. The covers have never been removed from these, but I have others which have. There's usually a pile of glue under the plastic and to my ears they sound better without the covers with the poles closer to the strings.
Their cables measure between 26cm and 27cm each.
There are mounting screws for both, but I've only got one set of springs.
The Jackson logo is wearing off on what was the bridge pickup and there are surface marks on both pickups.
£55 posted.
Do ursus deposit feculence in the thicket?
Here endeth the lesson.
thats cheap,really good pickups these.
