Today I swapped a pickup..
cj73cj73 Frets: 1003
And I'm disproportionally pleased with myself.  Is this the beginning of a long road to ruin?
This is the end product
But I was sightly bemused by these three circlular holes beneath the pickgaurd.  The guitar version of crop circles?
    edited January 2015
    Different hole patterns so you can't pass of a Mex body as a US or Jap etc etc .....or part of the CNC manufcaturing process
  • speshul91speshul91 Frets: 1397
    It's mojo
  • MattFGBIMattFGBI Frets: 1602
    It's weight relief.  Must have been heavy if it needed three holes.
    This is not an official response.
    contactemea@fender.com
    Really?  Doesn't look like much wood (and hence weight) was removed. :)
  • WezVWezV Frets: 16733
    yeah, having done weight relief holes they would need to be a lot more of them drilled deeper to make much difference.  then maybe you can reduce the overall weight by 20 - 30% tops.  to go beyound that you need to start with proper chambering
    these 3 holes will be an ounce or two at most
    Sorry, it's just for the jig in the factory! Guess I need to be careful what I say....
  • I think he might be joking?
    There's enough weight missing from a strat anyway by the time you've removed the wood for the pickups, control cavity, and trem cavity.  :)
    For substantial weight reduction, I'd consider removing those 22 metal stripey things that are scattered along the neck.
    I thought you might be joking  - but you neverknow what somecompanies will claim is a feature!   best bet is a smiley face on the end of a joke
