Removing sticker glue off a nitro finish
GassageGassage Frets: 30927
If you've a lovely old guitar which someone once put a 'TC Electronic' or some such sticker on it, with typical sticker glue, how do you remove the glue residue?
I'd use lighter fluid as a default, but assuming that'll also strip the Nitro?
  • Cover it with a Pete Cornish sticker? ;)
    9reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • BigMonkaBigMonka Frets: 1777
    I don't know its effect on nitro but acetone (nail varnish remover) normally works on sticker glue
    Sellotape.
    Place it over the glue residue, then peal it off, do that a few times and the tape will remove it.
    Polish and job done.
    (disclaimer: I've never tried this on a nitro finished guitar, but it works on plastics)
  • DartmoorHedgehogDartmoorHedgehog Frets: 892
    edited January 2015
    BigMonka said: I don't know its effect on nitro but acetone (nail varnish remover) normally works on sticker glue
    I'm pretty sure acetone will dissolve cellulose paint.  Meths may be OK (
    but I haven't tried it, just a guess)
  • richardhomerrichardhomer Frets: 24811
    edited January 2015
    Warm soapy water is always a safe bet.
    Lighter fluid (or 'naphtha' as Americans seem to insist on calling it) is recommended in Dan Erlewine's book - though I've never tried it myself.
  • GassageGassage Frets: 30927
    Silly as sounds, Vodka someone else suggested. On the basis I'd be too pissed to see the sticker I guess.
  • DamianPDamianP Frets: 499
    I use Naphtha/ lighter fluid.
    Not acetone! Acetone will remove the finish.
  • Warm soapy water is always a safe bet.
    This is precisely the type of comment Holnrew was on about when he called this place seedy.
    I see what you've done there Mr Random.... you've mistaken the word 'water' for the word 'breasts'. Easy mistake to make.
  • IanSavageIanSavage Frets: 1319
    I'm pretty sure that isopropyl alcohol will do it (it'll definitely get rid of the residue), I wouldn't bet my house on it not removing the nitro but I'm 97% sure it wouldn't.
  • ICBMICBM Frets: 72411
    WD40
  • DannyPDannyP Frets: 1681
    Breasts
  • Tried same with many things,but worked best with Lamp Oil,I accidently found in storage.Slow process.tough!
  • FelineGuitarsFelineGuitars Frets: 11596
    Lighter fluid or meths
  • stonevibestonevibe Frets: 7151
    WD40 works a treat as well.
  • WezVWezV Frets: 16716
    what he said.
    now about that discoloured nitro under the sticker.  I have had good luck evening it out with a rebuff with compound like t-cut.  but sometimes it can go too deep  - that's not so easy to sort
  • Lighter fluid. Definitely not water, warm, soapy or otherwise.
    Martin recommend (or they did when my guitar was made about 25 years ago) warm soapy water as a good way of getting stubborn marks off their nitro-cellulose finishes.
    Clearly they/I mean on a slightly damp cloth - rather soaking the guitar in the bath...
    Bloody hell- it's been in there 30 mins and I added some bleach as I wanted to relic the guitar. Darn.
    Yeah, a warm towelette is not just good for cleaning curry off your face!!
    if you can still ring water out of it its too wet, but a damp cloth will be the safest way of cleaning an old nitro finish.   just not sure it will be enough to get the glue off here - at least not without a lot of rubbing
