Rickenbacker owners: Rick-o-sound into 2 amps help needed...
scarry67scarry67 Frets: 143
Just tried out my 360 into 2 amps with 2 leads, one from each jack. It worked nicely but only when I half removed the lead from the Rick-o-sound jack so that it was solidly but not fully in. Clearly this can't be recommended method. Are you supposed to buy a Y adaptor taking both leads? Any help appreciated.
  • JayGeeJayGee Frets: 1260
    The Ric-o-sound socket is actually a "stereo" jack I believe so yes, you need either a 'Y' lead or a stereo lead running to a splitter box (which I think would be my preference).
  • scarry67scarry67 Frets: 143
    Sounds slightly expensive? I'll get on eBay to check. Can't see me using 2 amps often due to space but it's fascinating sound with fx grown in...
  • ICBMICBM Frets: 72450
    Yes, you do need a proper splitter - if you use two cables, even with one pulled halfway out, you actually get the combined signal of both pickups through both amps... so you aren't getting the full picture of what it sounds like.
    If you hear it properly, the effect is really amazing and opens up a lot more options, particularly putting different effects on each pickup.
    You could build a splitter box for about £10 if you do the work yourself. The box is better than a Y-cable because it's much easier to fix any ground loop issues.
  • WezVWezV Frets: 16733
    edited October 2013
    yeah, go for a splitter box.  You need:
    1x stereo lead.
    2x normal leads.
    1x stereo jack socket
    2x normal jack sockets
    1x box
    you would then also have the option of adding an on/off switch for each pickup, but that would need more parts
    You don't need that because there's one on the guitar :).
    But a ground lift switch for one of the outputs might be a good idea, since you can get a ground loop between the two amps otherwise.
    Wish my Dad had taught me soldering and DIY...
