Les paul style guitar with a flat radius neck?
    edited February 2015
  • Philly_QPhilly_Q Frets: 22925
    From a bit of research I was doing yesterday, I've learned that the Larrivee RS-4 has a very flat radius - 16" to 20" compound.  It's a 25.5" scale length as well.
    You might not like the look though, and good luck finding one anywhere!
  • FortheloveofguitarFortheloveofguitar Frets: 4291
    Hey all!
    I'm getting back into Les Pauls at the moment. Loving that thick big sound that my strat cant give me, even with humbuckers.
    Having set the les paul up i'm not at home with shredding on it should the mood take me as i cant get that nice low action because of the 12'' radius.
    Can you guys recommend anything that is in the les paul shape with set neck etc that has a lovely flat radius board or a nice compound board?
    Many thanks
    What is low action by your measures??
    I don't think its really a height thing and much more a radius issue.
    The string height measurements on a 16'' plays fantastic but the same measurements on this 12'' is like i'm fighting with it, making hard work of it if you will.
    Maybe a filing job on the saddles to suit the radius more is in order like someone else suggested earlier. The limitations of a TOM Bridge
    They look great just the price of them that's ugly lol
  • My Kramer Assault 220 FR has a very flat radius- 14 inches- and that is Les Paul style :) Is floyd'd though...
  • Hertz32Hertz32 Frets: 2248
    Ibanez CLM1?
    'Awibble'
  • guitarfishbayguitarfishbay Frets: 7961
    Fortheloveofguitar;513174" said:
    bingefeller said:
    Fortheloveofguitar said:
    Hey all!
    Many thanks
    How is your tailpiece set up? If it is screwed down low it would make stuff like string bending a little more difficult, could be contributing to the 'fight'. You could try raising it slightly to see if that improves the feel. As a precaution I'd slacken the strings before raising the tailpiece, not sure if it is 100% necessary but I'd do it anyway to be safe.
  • guitarfishbay;513266" said:
    Hey all!
    Many thanks
    How is your tailpiece set up? If it is screwed down low it would make stuff like string bending a little more difficult, could be contributing to the 'fight'. You could try raising it slightly to see if that improves the feel. As a precaution I'd slacken the strings before raising the tailpiece, not sure if it is 100% necessary but I'd do it anyway to be safe. [/quote]
    Hi Buddy
    The tailpiece isn't screwed all the way down.
  • ICBMICBM Frets: 72404
    Does your Charvel have a Floyd?
    If so the locking nut will make the guitar feel easier and more 'direct' to play because there is no extra length of string at the headstock - same sort of effect as the bridge but more extreme. When you bend a note on the Gibson, the string behind the nut will stretch too, meaning that you have to push the string further across the board for the same pitch change.
    If it doesn't have a Floyd ignore that!
    Also for probably about £200-£300 you could have the Les Paul refretted with a flatter board (planed flatter when the frets are out) and bigger frets…
    Hi @ICBM
    Thanks for your input
    The Charvel doesn't have a Floyd. Is a standard TOM as well.
    £200-300 for a refret and to flatten the board isn't to hard on the wallet so could be an option.
  • EvilmagsEvilmags Frets: 5158
    Looking at Vigier if your after a super low action also makes sense. The carbon in the necks make them very stable, hence easy to set up low.
  • BucketBucket Frets: 7751
    My Gibson V has a 12" radius and that's one of the slickest, nicest-feeling guitars I've ever played. Very low action.
