For those that play classical, or nylon stringed guitars in general, which strings do you prefer?
I've been experimenting with Savarez Alliance/Corum reds. They basses sound great, and are very flexible (when loose they are like string) but don't seem to last long - after a month the silver windings have gone where they rub against the frets.
The trebles I'm not so sure about. They are very crisp, but a bit glassy. The other problem was the strings took over a week to settle in.
Right now, I've switched to Pro Arte composites for a comparison. Initial impressions are that they settle in much quicker (hours), the basses are stiffer but don't sound as good as the Savarez, the trebles are quieter and warmer, the composite G I'm not sure about yet.
I'm a nylon string novice, so it's probably just me, but does changing strings on a classical usually take a couple of hours?
What's your experiences?
I find changing them a pain and usually end up with a youtube guide on as I forget how to tie them between string changes. I'd say a good hour changing them then a week of constantly tuning up before they are stable. At least they last longer that a set a Phosphor Bronze. I've only tried Pro Arte's but would like to experiment a bit.
Given my hatred of restringing nylons - how long they last is probably the most important factor to me.
