Why is it so hard to buy electrolytic caps for valve amps in this country?
I'm working on a couple of Traynor amps and want to replace the electrolytic caps bypassing the cathode resistors. They're 25uF / 25V. Why can I not find anywhere in the UK that sells them at a reasonable price? I guess I can use 22uF instead, but still - they're readily available in the US. Bah!
R.
They are massively overpriced here if you what something that isn't 1uF, 2.2uF, 3.3uF, 4.7uF, 10uF, 22uF, 33uF, 47uF, 100uF etc. Other than Tube Amp Doctor, also in Germany, Banzai do a good selection at a reasonable price but as I mentioned in a thread a few weeks back their service level leaves a fair bit to be desired - an experience others echoed.
https://www.banzaimusic.com/search.php?mode=search&page=1&keep_https=yes
You will get your bits but expect to wait 7-10 days
Haven't a clue about this stuff tbh, but have you tried rapidonline.com 22uf 25v Axial Electrolytic Capacitor
Eqd Speaker Cranker clone
http://www.audiocap.co.uk/ft-axial-22uf-63v-10x30mm-a22006310030-408-p.asp
Just dont look at the price!!
