Hoping I'm being daft and missing something obvious here guys!
I want to replace the wiring in an old gordon smith g60 as I'm replacing the pickups with some oil city humbucker size p90s, and want to keep the original loom intact due to the coil splitting etc.
Having taken the old pots out I'm not finding it easy to find the same size replacements. The threaded shaft is only 1/4 inch long and similarly narrow. I think these ones are about right, but can't see the linear equivalent:
Should I just be getting pots with a longer shaft and trying to fix the height with two nuts?
Any advice or suggestions?
cheers
