I was thinking a smaller combo really, don't need anything too big although certainly not averse to a head or bigger wattage.
I suppose Randall are probably the best bet, but the modern RG50 is a tube head, I'd have to hunt for an old one. Although I've just discovered the Nuno sig practice amp, looks very interestingly retro.
EDIT: found some demos of the Nuno sig 15w amp. Would make a nice ornament.
Sessionette 75 or Rockette 30.
Fantastic sounding amps, always available on Ebay £50-£150 depending on condition.
Tbh, though, they do sound much better with pedals in front of them than the on board distortion.
As he doesn't say anything, he's bearable although his playing is rather limited for demoing tbh.
it was definitely a Fender SS combo) I had some significant problems. I was used to playing through my own amp (valve Laney off the ark) or rehearsal studio Bandit or Valvestate and using an OD or clean boost for solos.With the Fender it just utterly crapped out with too much signal in the front (and this is a strat with vintage style pick ups going in to a fairly mild boost). The guitarist in the other band was using a strat through a Boss Blues Driver but he kept the Boss at unity gain, so just using it as a distortion pedal (which sounded pretty awful but they had a horn section so he was fairly buried in the mix).
