oldGD not really an acoustic
this probably should be under the electric section, but it does compliment my dobro , this selmer lap steel is as old as I am & probably in slightly better condition, mike
  • ICBMICBM Frets: 72448
    Very nice!
    I recently worked on one very like that, not in quite as nice condition and possibly a little older (?) - looked slightly more '1930s gothic' although it was made in 1946 - with an original amp built into the case. It's the oldest British-made electric guitar amp I know of.
    Sadly the amp could not be made operational and safe without destroying a lot of its historical value, so I left it as it was. The instrument sounded fantastic plugged into a modern amp though.
  • I love the brassware :)
  • Is this for sale? Or are you simply, and understandably, being a proud owner? :-)
  • Gorgeous wrinkly! Beautiful machine.... Having come across an old beaut myself lately (check out my selmer amp discussion) there is a lot to be said for having an old piece of history close by (insert wife jokes here....). Great to see it going to a good home and being used.... Congrats!
  • wrinkleygitwrinkleygit Frets: 259
    this is something I bought for a rainy day, although at the moment I prefer my dobro, haven't really bonded with lap style yet, does sound incredible thro an amp tho' screams like a banshee if you crank it, all the electrics work with no crackles it really is in amazing condition, I did see one on the internet with a serial number of about 60 lower than mine described as 1948 so I guess mine must be around 1950 build date
    I can't remember for sure from the one I worked on, but I think the pots will be wirewound types, which don't crackle like the more modern carbon-track ones do. The pickup on that one was really hot too, I can't remember the resistance but you're right, really screaming when cranked. I suspect they were never expected to be used like that - the designers would have expected the controls to be used like the ones on a radio or something, and not just turned up full :).
    Later Selmer amps had a label on the back which said this:
  • SassafrasSassafras Frets: 30294
    Judging by the strings twisted at the tuners I'd say it's got the original strings still on there. You just don't see that on modern guitars anymore.
