amp help
1nten5e1nten5e Frets: 245
Tonight at rehearsal we had a power cut in between songs, seems to have done something to my roadking head, it's half as loud as it was, and there's a noise like wind or waves in the background with the occasional popping or clicking......I have an aac file if anyone wants to hear it......any pointers? I dont think its power tubes as its happening on all channels whether set to EL34's or 6L6's
  • bertiebertie Frets: 13569
    [total guess] is it valve rectifier ?  as that's a common element  and it does sound valvey [/TG]
  • ICBMICBM Frets: 72490
    More likely to be a preamp valve. Rectifiers usually either work perfectly or blow fuses.
    I'm not sure of the exact layout of that amp, but there will definitely be some preamp valves that are common to all channels.
  • 1nten5e1nten5e Frets: 245
    edited November 2013
    ICBM cheers, there's a schematic here
    I'm just waiting for it to cool down, V5 sounds noisy with a tap test, I'm guessing it could be that
    Thanks!
    V5 is the FX loop valve, so if you bypass the loop and the problem goes away, that's the most likely. All the other valves operate on both channels in some way except V3, so it can't be that. V4 is the reverb so it won't be that either.
    It didn't go away when I bypassed the loop on the footswitch, but it does seem to have gone with a spare tube in V5 .....odd
    would you recommend sticking with the Mesa tubes or is there something better?
    Not with the footswitch - that just bypasses the loop connections. You'd have to bypass the whole loop circuit including the Solo function, I assume there's a switch on the back if it's like the Dual Rectifier. It does sound like you've got it if the problem has gone away.
    There are a lot better than the Mesa valves, it's hard to know where to start! Mesa are currently using JJ now as far as I know, which I like for power valves but not at all for preamp. If you do try different ones, avoid anything Russian-made - or even JJ if you can - in V3 and V5, which are cathode followers and tend to kill them. (And which may be why that one failed first if there was a voltage spike.) The bog-standard Chinese ones are fine though.
    The one I pulled from V5 was a rusky
    Crikey, it's a valve minefield.....I've no idea what to get :/ I'm guessing I should go for a good quality brand in V1 and 2 at the very least
  • NerineNerine Frets: 2175
    I've just wanged some Tung Sols and Genelex in my 800. They sound pretty sublime in that.
    Be careful about a Tung Sol in V2, if you have - they're Russian and it may well fail. That's why Vox ship the AC30CCs etc with Tung-Sols in V1 and V3 and a generic Chinese one in V2. (Like the Marshall, V2 is a cathode follower in modern AC30s.)
