Just bought a Red Panda Particle!!!
BintyTwanger77BintyTwanger77 Frets: 2232
I bit the bullet (after much drooling from afar) and bought a Red Panda Particle Granular Delay. It looks insane, can't wait to get stuck in with it. The RP Context Reverb looks great as well (next step is stacking 2 reverbs), so may well be getting a bigger board to accommodate that in the near future.
Does/has anyone else own(ed) a Red Panda Particle? What did you think?
  • Insane, brilliant. Loved sticking it into an SMMH for looping. Lots of time for Red Panda here.
    Stacking reverbs is boring though. A real man stacks granular delays :D
  • TeetonetalTeetonetal Frets: 7807
    Really fancy this pedal and the rasta.. so let us know how you get on :)
  • DopesickDopesick Frets: 1509
    Great pedal, capable of so many sweet sounds. If money were no object I would've kept hold of mine for sure.
    That would be a great name for a news anchor: "Hi, I'm Manly Delaystacker, and you're watching CNN..."
  • WazmeisterWazmeister Frets: 9570
    edited October 2015
    I sold mine, but really loved the 'reverse' feature.
    Enjoy.
  • I am an owner of one of these. Mines started playing up :-( the switch is noisy as hell when engaged and its been suffering from signal bleed :-( its a shame because it can be brilliant at times
    Well that's worrying...
  • I will report back once I get it open and have a butchers
  • DesVegasDesVegas Frets: 4557
    Good score, that thing looks bonkers
  • Really fancy this pedal and the rasta.. so let us know how you get on :)
    Will do... should be delivered today.
  • Ok - update
    I found the problem. My super duper angry fuzz was upsetting the red panda.
    I put a buffer inbetween them and hey presto, silent switching and no bleed.
    so there you are kids. Pedal placement can make a difference.
  • meltedbuzzbox;811929" said:
    Ok - update
    I found the problem. My super duper angry fuzz was upsetting the red panda. I put a buffer inbetween them and hey presto, silent switching and no bleed.
    Great to know, thanks!
    Pedal has arrived and getting some AWESOME sounds, but I think there might be a problem.
    I'm not sure whether the switch below the red LED light is working, I thought it was supposed to clip the signal, but the sound doesn't seem to change and the red LED light doesn't come on or flash at all.
    Is this a fault, or am I being daft?
  • Paul_CPaul_C Frets: 7794
    according to the manual the switch selects what the expression pedal affects
    "expr
    Selects delay/pitch (up) or param (down) as the expression
    pedal destination"
    "expr
    pedal destination"
    Cool, thanks. So the light not coming on when I flick the switch is not a fault?
    "expr
    pedal destination"
    he is right.
  • meltedbuzzbox;812193" said:
    "expr
    pedal destination"
    he is right.
    Alright, so (and sorry for being a Luddite here), as I'm not using an expression pedal, both the switch an the red LED light will never be in use/come on?
  • sounds about right... its been ages since I plugged an expression pedal in.
  • Excellent, relieved I didn't receive a faulty one now. Thanks for all your help. This pedal is fantastic. The dens delay mode is something else...
  • I am currently using dens as well.
    I was using dtune as well earlier. Had some great synth/organ/12 string sounds going on
    "expr
    pedal destination"
    the manual says :
    LEDs
    The upper LED blinks red when clipping occurs.
    The lower LED is blue when the effect is engaged.
