Bridge pickup advice
fretmeisterfretmeister Frets: 24337
I have a lovely strat loaded with Lollar Black Face singles. They are awesome. But I need some grunt from the bridge, so I'd like to drop a bucker in there - ideally without needing to change the pots. Is there a humbucker that will play nice with a vintage control pot?
  • SD Lil '59 should do the trick.
    Although, honestly, I'd probably be a total hooligan and put a Hot Rails in there :D
    <space for hire>
  • ICBMICBM Frets: 72407
    The Li'l Screamin' Demon is miles better than either of them. It actually has tone, unlike the Li'l '59 ;), and is less over-the-top than you'd think from the name - it will balance better with the singles than the Hot Rails. The JB Jr. isn't bad either.
  • littlegreenmanlittlegreenman Frets: 4992
    edited November 2013
    I put DM Freds in everything, and you may just have one of them still lying around ;) Might need some woodwork doing though.
    littlegreenman < My tunes here...
  • martinwmartinw Frets: 2149
    I prefer the Dimarzio Chopper.
  • OilCityPickupsOilCityPickups Frets: 10487
    Is what you want 'actually' a humbucker? There are plenty of high output Strat units from many different makers that keep a 'stratty' quality while allowing more drive.
  • FX_MunkeeFX_Munkee Frets: 2478
    I can echo the NOT a li'l '59. I had one in the bridge on my strat and it sounded nasty, shrill and nasaly.
    As GuitarWeasel said, what about a Quarter Pounder or similar?
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
  • fretmeisterfretmeister Frets: 24337
    Deffo want a bucker.
    I have Iron Maiden inspired tunes to play.
    Didn't know about the Dimarzio Chopper - I'll have a look at that too, ta
    edited November 2013 tFB Trader
    Then I'd get out the router ... them nasty little rails things sound about as much like a real humbucker as I sound like Ian Gillan on vocals :)
    Spot on? ;)
    I'm inclined to agree. I've not tried the Lil screaming demon, but the others have their own voice. Not a bad voice, but not like a proper bucker either. It's cool in its own way though. I like most rails (not hot rails though) but as they're own thing - an approximation or a unique voice.
    I think the rails pickup sound works well in the bridge of a Strat, as it doesn't overpower the single coils, and can use the same 250k pots without any issues.
    Of course, it doesn't sound like a proper humbucker, but it can still be a really useful sound.
    The problem I have is that pretty much all the advertising (and even the name with 'Lil 59') would lead you to expect a proper, full humbucker tone from a Strat sized pickup. That's not actually possible due to the physics involved in pickup design. Usually what you get is a somewhat nasal, overly compressed 'too hot for it's size' sort of sound. Magnet choice is limited with these designs as you have to develop a lot of field strength from a small package ... and that leads to brittle trebles and characterless mids.
    Just not my idea of a nice sound :)
    That's why I recommended the Chopper.
    I think you're right in what you say when talking about the ones that imply they can sound like a full-on HB. Dimarzio don't claim that though for the Chopper (or Fast Track or Cruiser but I've not tried those). They sell it as just beefier than a single coil which I think it achieves. I'd guess the one @ICBM mentioned is the same. The SD Cool Rails is ok too, although not as open sounding and natural as the Chopper.
    There's nothing nasal or overly-compressed about the Chopper; it just sounds alike a particularly beefy single-coil, with no hum.
  • mike_lmike_l Frets: 5700
    Davey Murray uses hot rails. Jus' sayin'
    I'd look at a alnico5 'bucker which can be split.
