How many different kinds of instrument in your house?
  • dogload said:
    Electric guitars (6 & 12-string)
    Acoustic guitars (6, 12 and classical)
    electric Mandolin
    Acoustic mandolin
    Bouzouki
    Bass guitars
    Flute
    Oboe
    Alto Sax
    Recorders
    Whistles
    Bamboo flutes
    Synths
    Drums (various)
    Bugle
    Appalachian Dulcimer
    Epinette des Vosges
    Violin
    Various percussion
    Audio Generators!
    You are Dik Mik and I claim my £5! :-)
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • dogloaddogload Frets: 1495
    electric Mandolin
    Acoustic mandolin
    Bouzouki
    Bass guitars
    Flute
    Oboe
    Alto Sax
    Recorders
    Whistles
    Bamboo flutes
    Synths
    Drums (various)
    Bugle
    Epinette des Vosges
    Violin
    Various percussion
    Audio Generators!
    Lol... yeah, well I always wanted to be a Technician of Space Ship Earth!
    When I came across them in a car boot sale, I just had to!
    No-one's mentioned the majestic tambourine. What's wrong with you all.
    Can't beat a tambourine, well, you can but you know what I mean.
    Wonderful instrument, very soulful.
  • ICBM;914536" said:
    I forgot Stylophone… and Theremin.
    Theremin, eh? Is it useable? I've always fancied one but figured it'd end up as a paperweight :)
  • ICBMICBM Frets: 72385
    Included in 'various percussion'. There's also a triangle I think.
    It's one of those little kit ones that looks like a walkie-talkie. It does work but I've never used it for anything practical either!
  • GassageGassage Frets: 30926
    Both types.
    Gibson and Fender.
  • andrewandrew Frets: 47
    edited December 2015
    Gassage said:
    Both types.
    Gibson and Fender.
    This :D
    Sarcasm is often hard to detect in writing. If in doubt - yes, I was taking the piss.
  • impmannimpmann Frets: 12667
    Electric guitars - 6 & 12 string
    Acoustic guitar
    Classical guitar
    Lap steel
    Uke
    Electric bass
    Omnichord
    Synth
    Descant recorder
    Treble recorder
    Alto recorder
    Melodian
    Stylophone
    Tambourine
  • Electric guitars
    Acoustic guitars
    Basses
    Rhodes Stage Piano
    Upright piano
    Hammond organ
    Tin whistle
    Swannee whistle
    Descant recorder
    Tambourine
    Alesis SR-16
  • NomadNomad Frets: 549
    Electric, acoustic and classical guitars
    Electric & acoustic bass guitars
    Acoustic piano
    Hammond organ
    Mono synthesiser
    MIDI controller keyboards into computer and/or hardware sound module
    Tenor sax
    Flute
    Violin
    Harmonicas
    Tin whistle
    Nomad
  • ChalkyChalky Frets: 6811
    Many of the above but also an EWI5000 electric wind instrument.
  • @Nomad nice to see another Hammond user. Mine's an L102, woss yours?
    Mine is an A100 with a 145 Leslie.
    The A100 is a B3 in a rather bigger lump of furniture and has a Hammond tone cabinet in the bottom and a built-in reverb. It was basically the home organ version of the B3, and has all the B3 features - 4 sets of drawbars plus 2 for bass, percussion, vibrato/chorus, inverse preset keys.
    The tone cabinet is what was originally supposed to be used with Hammonds (Laurens Hammond was against Leslies at first). The built-in cab has two 12" speakers for the dry sound and another power amp and 12" speaker for reverb (so a 3x12 overall). The Leslie is the traditional type with a slightly shorter cabinet (147 is taller - same height as a 122), and is designed to work from a tapping from the organ's power amp rather than the B+ line on a normal B3. 15" bass driver with rotor, spinning horn, 40W 6L6 amp. I use it Leslie-only for the dry sound and blend in some reverb (it has a switch to go between internal, Leslie or both, and keeps the reverb on all the time).
    It's a beast and far too loud to get it into overdriven sounds.
    The L100 series are real-deal tonewheel organs as well and I think are the same era (my A100 is a 1968, I believe).
    Got a Leslie?
    Nomad
  • @Nomad no, but I have 2 good patches on my Quadraverb. I guess you have more space than I do, but if an affordable deal on a Leslie came my way I'd probably try to make room for it
    The Korg G4 is a very good Leslie simulator pedal. Does fast/slow/stop and overdrive.
    I suspect I'm just willing to put up not much space. :)
    I think my 145 worked out at about 400 quid or so. Need to make sure that both the organ and the Leslie have the same type of connector. On the organ, there's an add-on bit that hooks into the signal and power and routes them to a box with the Leslie connector. Also has one or two switches for fast/slow and swapping between internal speakers and Leslie. With that lot fitted and the cable connected, the Leslie powers up automatically when the organ is switched on.
    There are several adapter kits - some for the speakerless B3/C3, and most for various other organs with internal speakers (Hammond and other makes). There's plenty of material on the net which should help you home in on what you need for the L102 and whatever Lerlie you want/find. Various vintages of Leslies came with different multi-pin connectors (mine is 6-pin). Also, watch out for later Leslies and ones that were budget versions. I know of one that only has a full range driver and rotor - no treble driver and spinning horn - and it doesn't sound right at all. Some later ones have solid state amps, possibly no bass rotor, etc.
    Nomad
  • @Nomad thanks for info :)
    Just had a quick google for the A100, noticed it has reverse white/black keys at the left end of each manual. What do they do?
    The reverse keys are for selecting presets. C switches the manual off, C# to A are particular drawbar setups wired internally, and Bb and B pick the two user drawbar settings. The internally wired ones can be changed by opening the back of the organ, looking up a chart and moving wires around on a terminal block with the aid of a screwdriver.
    The factory presets are mostly pipe organ sounds.
    Nomad
  • @Nomad thanks, wow, and YLSNED :)
  • Paul_CPaul_C Frets: 7788
    Piano
    Electric/acoustic/classical guitars
    Electric basses
    Mandolin (on loan)
    Ukulele
    Melodica
    Xaphoon
    Various drums and percussion, cymbals etc.
    Cajon
    Djembe
    Microkorg
    Stylophone
    Ocarina
    Mouth Organs (most on loan)
    Kazoo
    Aye, programming a preset by pulling the back off, getting the screwdriver out, and looking up a chart for the wires-to-terminals drawbar mappings is proper hairy-chested synth stuff.
    Are you aware you have to oil the tonewheel mechanism? Use proper Hammond oil, and I'm told once a year or so.
    Nomad
