Jooks, just for clarity in the original post can you re-write Adolfhipster name separately next to @Zodiac51. It's just currently with the format at a quick glance it looks as though Z51 is actually listed as a badden rather than a victim.
Good work, Sir.
@Zodiac51 and @Adolfhipster - let me know when it is sorted and I'll update the list
cheers fellas
I agree with @Octatonic. The original post states that it has now been resolved but that's not the same as it not happening. If someone resolved a problem only once the issue was aired on here then effectively they are buying their way of the naughty list, rather than providing a good deal in the first place. That negates the purpose of a bad traders list and could see people using it as a stick to threaten people with rather than justifiably reporting an issue. There is a good trader list to balance it out after all.
In this particular case it wasn't a single issue with a member, it was two. The attitude in return wasn't to fix the issue or explain understandable issues but either bitching about the whole system or the response of "It's only £30, blah blah!".
The forum's system isn't complex - You pay, they send or they pay, you send. All along decent communication is just good manners. The whole system is based on trust and my attitude is that if you don't want to stay within that structure or when you fuck up you attack the system rather than accepting some personal responsibility then use a different system to shift your gear.
You would deal with someone with 99% feedback right?
