If you've got a 3 channel amp, and you're interested in a swap. Send me a PM.
Parallel loops IIRC which may be a deal breaker.
I think you'd be unhappy with the 104EL34 S1 if you prefer the EVH to the JVM to the point you want to sell the Marshall. 1046L6 is worth a look if you find one, the shared EQ is less problematic than on the 104EL34 (OD1/OD2 are voiced more closely IMO) and it sounds bigger and more metal. Be aware the 104 heads are about 27kg and the weight is more at one side than the other.
