Switching channel on non-midi amp using midi...
BodBod Frets: 1301
Is there a cheapish gadget that will do this? I'm using my Pod HD500 using the four cable method to connect to my HT5, and would like to be able to change amp channel using the midi out on the pod. I've seen expensive switching systems that can do this but they are far too complex for my needs...
