Behold my massive board of pedals
1116117119121122394
  • @TeeByrd Nice board! How do you use your Mantra? Have the same one and struggle to know where it's strength lies! So versatile!
  • hotpickupshotpickups Frets: 1822
    I just picked it up from his house so no waiting list. However that was over a year ago so things might have changed
    RaymondLin;955156" said:
    @hotpickups did you order the Lazy J Cruiser direct from Jesse and was there a waiting list?
  • TeeByrdTeeByrd Frets: 159
    edited January 2016
    @stefken147 depends which amp I'm using. If you turn both the bass and the table knobs full clockwise you scoop out the mids. I use that more for My Swart STR Tweed. Both fully counter clockwise kicks the mids back in. With the Morgan I like both halfway between mids and a flat eq. Is your Mantra the standard one? I got the custom version with the low gain switch and keep it on that setting 99% of the time.
  • Paul_CPaul_C Frets: 7788
    Paul_C said:
    The incoming H9 prompted a rethink on layout / power / MIDI routing, so I thought it'd be better to start again
    if you decide after rearranging that you've got room for a Count To Five then mine's up for grabs ;)
  • Gassage said:
    dogload said:
    Well, it's been ages since I posted my pedalboard... mostly coz it's been pretty stable for a while. However!
    I finally got myself a Pedaltrain (my old wooden case is starting to show the strain :(  ) soooo...
    However, in the process of setting it out, I managed to drop my Hazarai pedal and bend the white Hazarai control, which seems to be behaving oddly, and as yet I haven't been able to test it properly. I'll be pretty gutted if that's knackered! I use the reverse delay quite a lot.
    ahhhh thats where that ring mod went.
    @meltedbuzzbox
    Do you have to use two postcodes to store that?
    @Gassage thats not mine mate
    note the absence of any moogerfoogers ;-)
    Yeah, mine is the Prymaxe one too, definitely prefer the low gain mode. Will have to have another play about with the tone stack. Cheers!
  • Not a complete board, but so much versatility here.
    http://i.imgur.com/RrO0LlE.jpg
    edited February 2016
    I love the simplicity of this compared to lunking the 30kg flight case of the previous board.
    All because a couple of gigs ago I had a problem setting up and couldn't get any sound, didn't have time to fault find, so I went totally old school:
    Guitar --> cable --> Amp
    And it sounded fine.  That amp was a JVM410h, this Orange is different.  It's a ton lighter for a start!
    This small board is just a pure, functional, gigging workhorse which does more than enough:  two drives which stack well give a combination of clean, crunch, gain, and lead boost.  And sound great -- (that DS-1 is modded though).  The wah and phaser add a bit of quack and swirl as required.  And in the FX loop the obligatory echo (and I use an external tap tempo switch live), and the PS-6 Harmonist like a small Swiss Army knife, which is mostly used a chorus pedal, but does some great whammy dives and "crazy horses" rises, and those Thin Lizzy style second guitar harmony lines.  (Very fast tracking and does great + or - octaves too which can be fun for solos.)
  • Mine as of about midnight last night. Patiently awaiting the H9, and will need to wire that in and two more midi cables...
    http://i238.photobucket.com/albums/ff193/guitarsforminnaars/Mobile Uploads/74636BAB-610F-43BE-B69D-8458DAE5D0EF.jpg
  • being a lefty I assume you are left footed too @GavRichList ?
    Don't think you left a big enough gap... ;)
  • I am indeed @meltedbuzzbox - if you'd ever seen me play football, you'd know it to be profoundly true
    don't even joke!
    three sold, but the relapse has begun!
  • thats one of my all time favourites the delay lab
    If it wasn't as big as a double decker bus I think I would still have it.
    And roughly the same weight too. Love mine though.
    Im a righty but use my left foot for pedals...never found it comfortable to use my right.
  • Just sorted out a new power supply, so was testing it out and all the cables not neatened up yet, but you get the idea: http://i.imgur.com/lxyRtmV.jpg
  • Wow you like your delay don't you @BintyTwanger77 ;)
  • @hotpickups That I do, mannie, that I do. I've got a Count To Five preordered as well! I may have gone too far.
