Anyone use leccie guitar strings
on their electro acoustic guitar? Which ones work ok?
  • ICBMICBM Frets: 72483
    Any particular reason why you would want to? They usually sound rubbish. I occasionally get acoustics to set up which people have put electric strings on…
    If it's to make it easier to play, a set of normal acoustic 10s on a properly set-up guitar is almost as easy to play as 9s, so there's no real advantage to going lighter.
    If it's for a magnetic soundhole pickup, DR make 'Zebra' strings which are a mixed winding of bronze and steel, and they do actually sound quite good. Not that cheap though.
  • GassageGassage Frets: 30929
    There's another reason- nickel wound strings are more softer and more elastic. Hence they don't pretension the 'belly' of an acoustic like bronze/brass based ones do. So the vibration transfer is much less.
  • thermionicthermionic Frets: 9658
    edited February 2016
    Gassage said: There's another reason- nickel wound strings are more softer and more elastic. Hence they don't pretension the 'belly' of an acoustic like bronze/brass based ones do. So the vibration transfer is much less.
    This post is severely lacking in
    S C I E N C E.
  • The only reason being that I have packets of Roto sound yellows 10-46 coming out of my ears and want to use them up.The ones on my leccie guitar have been on for 2 years....suppose I could bung a new set on that.
  • SassafrasSassafras Frets: 30300
    I wouldn't rush into anything. I've had the same strings on my PRS for about 6 or 7 years and it still sounds great.
