I've been thinking about it for ages and I reckon now is maybe the time for me to give a tele a go. I can't afford a fancy one but to me part of the appeal of a tele is it's cheap, rough and ready and not posh. I've played an Affinity tele and really liked it but had these concerns:
- pickguard. First thing I'll want to do is change the pickguard but have heard it's not a standard fender size? Is it a pain to find a black one to fit without going custom?
- narrower nut. The narrow neck on this feels really nice to me but is it a problem to find replacements? Or will any good luthier have no problem sourcing or making a nut to fit?
- thinner body. Does it really affect tone or sustain when plugged in that couldn't be compensated for with pickups?
- top loading bridge. As above re the body, is there really much noticeable benefit to string thru? Suppose I could always drill it in the future.
Or is there any real merit to saving a bit longer and getting a used CV 50s, or a used Fender MIM? As I said I've played an Affinity and liked it but that wasn't a long term test. I have a set of hipshot tuners I can drop straight in so that's one cheap guitar "problem" fixed. I didn't play it plugged in but had kinda factored in getting some Oil City pickups in it at some point unless the stock ones are any good.
The neck pickup is a bit lifeless (unless you remove the cover) but the bridge pickup is great fun and very authentic sounding in an early 1960s kind of way.
Affinitys/Affinities/Affinitii are fine guitars "as is" but there is a point where Triggers Broom sets in.
Judging by your comments I'd be looking at the CV50s or a MIM- a good, ready made guitar that the majority of future upgrades will drop into. Failing that, have you considered a Partscaster?
Tele Partscasters are easy to put together and you can get the spec you want from the outset (& mod it as your tastes change).
IIRC @lonestar ;; has a beautiful blue tele body for sale, get a neck, hardware and Robert's your mothers brother.
If you're thinking OilCity pickups, it's worth considering a harness from Ash too- excellent quality & a real improvement on virtually anything I've seen fitted in a factory.
Regarding the toploading bridge- some people prefer them. I THINK ICBM falls into this camp- lower string tension over the bridge = more twang?
Other guitars to consider - the Vintage Tele copies are superb and come up really cheap. There was one in the Kettering Crack Converters recently for £85. Tokai chinese ones are OK and cheap - although I'm not a fan of the pickups, the necks are OK. Finally the Harley Benton (Thomann) guitars - ok, the headstock is eaten up with the uglies but they are generally fine guitars... although some can be a touch heavy in weight.
Or as mentioned above, build something or buy a Partcaster - buy carefully and you can end up with a guitar that is greater than the sum of its parts.
I think you're all confirming what I knew all along though, that I'd get an Affinity and spend a fortune doing it up, only to have spent the same as I would have on a CV!
The CV teles do have vintage split tuners which I sodding hate, I restrung mine the other week though and managed it just fine
The best neck I've ever played was on a Squier Trohman tele. It was phenomenal... I'd love to buy one of those, but they've dropped off the face of the earth.
Yip I have this unloaded body for sale
https://i.imgur.com/bDbYKpi.jpg
• Youtube - https://www.youtube.com/@Goldeneraguitars
