http://www.northyorkmoors.org.uk/visiting/see-and-do/attractions/sutton-bank-national-park-centre
Our cycle trails use a mixture of natural and man made trails similar to those found in a purpose built trail centre. Using the same style of trail marking, the mountain biking trails available are:
Unlike a trail centre, large parts of our routes make use of existing bridleways that are shared with walkers and horse riders. Please consider other users, and expect to come across some gates too.
Basically just find some local trails, start on blue trails and work your way from there, ideally the trail centre should have a pump track to develop handling skills and teach you how to smooth out some bumps and jump off others.
I sadly gave up on the MTB as I'm a roadie at heart and didn't have the time to do both, but it's definitely good fun.
Also I'd consider some elbow and knee protection as well as full finger gloves with some padding, you will fall off every so often and speaking from personal experience a fractured elbow isn't a lot of fun (although not a serious injury)
Get yourself a sports rucksack to take puncture repair equipment, some energy bars and plenty of drink - if you're doing it right you'll be sweating buckets!
I also found this to be useful to give you an idea of what pressure you should be running your tyres at off road - makes a HUGE difference to the way the bike handles on the dirt: http://mtb.ubiqyou.com/ ;
And get yourself a decent tyre pressure gauge.
And then, one bike wont be enough, probably (same as with guitars) n+1
I'd also suggest getting some coaching to make sure you're doing things right from the start.
If you want some reading material, get a copy of Mastering Mountain Bike Skills by Brian Lopes/Lee McCormack, and/or Mountain Bike!: A Manual of Beginning to Advanced Technique by William Nealy (old, but nearly everything in it, is as valid as when it was written, and the drawings are brilliant!).
Basics to cover are the circle of movement i.e. how much you can let the bike lean under you, and how far forward/backward you can move (the William Nealy book I mentioned above covers this aspect very well).
Next would be braking, which is all about getting your weight back and braking as hard as you can with the front brake (rear brake should only be used for minimal braking).
Then mix in cornering, which the basics are pedals level with outside foot leading/inside foot trailing, lean the bike into the corner but get your weight over the bike (to maximise traction, think about getting as much weight on the outside grip and pedal as possible, so your weight is concentrated over the tyre contact points).
After that, think about wheelies, and bunny hops. The main thing from these is actually learning about unweighting the bike, and not about getting the wheels of the ground. Being able to just unweight the wheels is the difference between ploughing over an obstacle usually killing momentum, and just glancing over an obstacle and keeping speed.
I'm lucky, I have woods near my house that the local MTB club have built routes in plus there are recognised trails nearby. I haven't been out in a while but I've reckon you've spurred me on to get back in my stride!
If you really want to improve and build confidence a skills course is a great idea. I went to Tony at UK Bike Skills to build up my confidence after having a few big crashes and it was exactly what I needed. I haven't had a big off since despite my best efforts, and that was about 7 years ago. A lot of people scoff at the idea of a skills course to ride a bike but Tony's reputation speaks for itself.
Sadly don't get much time to ride at the minute and I miss it! Have a road bike for exercise but it's just not the same. Seems like we have enough on here to meet for a ride somewhere? I always found riding with others helps build confidence and skills.
Sounds like a great idea to me; however, when it's warmer please. I'm like a girl when it's cold.
