Marshall foot switch woes! URGENT!!!
My Marshall double footswitch is giving me jip! One of the buttons is buggered. I need a replacement button ASAP! Got a gig on Saturday. Where can I get just the button so I can wire it in myself? Mucho help needed!!!
  • Modulus_AmpsModulus_Amps Frets: 2592
    I have some here, but no chance of getting it to you tomorrow. Have you got a maplins nearby?
  • ICBMICBM Frets: 72544
    Is it definitely the switch itself - ie does it feel buggered? :)
    Cable failure is far more common on these.
    Yep it’s def. the switch it feels buggered!
  • rockmonsterrockmonster Frets: 839
    edited February 2018
    Which one would it be from maplins?
    The good news is that it doesn't have to be a specific type of switch - *any* latching footswitch which fits the hole will do, from a SPST up to a 3PDT. All it needs is to make and break one contact. (If you're using a DP or 3P switch, you can parallel the poles to make it more reliable, but you don't have to.)
    If you don't have time to buy one, do you have any old pedals you could sacrifice (temporarily) to get a switch?
    I have a joyo pedal I could butcher but i think it’s got six connectors on it which ones do I use?
  • VoxmanVoxman Frets: 4727
    If you're in London (I'm in North London) I have two and could loan you one.
  • Thanks very much but I’m in Andover in Hampshire. :(
  • ricorico Frets: 1220
    If you can get to Guildford, Andertons have a load of two button foot switches for a tenner.
    The Joyo should have a 3PDT, mounted on a small PCB. It's best not to try to get the switch off the PCB, it's very hard without damage and will stop you putting it back later, once you're repaired the Marshall properly.
    What I would do is cut the wires close to the PCB, leaving enough coloured insulation that you can see where to re-solder them. Bend the LED out of the way, don't remove it. Then use the middle terminal and one of the end ones in the row nearest the wires.
    Fanku for your Ossum advice ICBM!
  • nickb_boynickb_boy Frets: 1689
    I've got an old 2 button Marshall footswitch lurking from the days of an old 90s valvestate I had in the garage.  If that's any use let me know
    That was the spare one I had too!  Just too far away to help.
  • Yeah thanks for all the offers guys
