Cable failure is far more common on these.
If you don't have time to buy one, do you have any old pedals you could sacrifice (temporarily) to get a switch?
What I would do is cut the wires close to the PCB, leaving enough coloured insulation that you can see where to re-solder them. Bend the LED out of the way, don't remove it. Then use the middle terminal and one of the end ones in the row nearest the wires.
