I suppose really it should be 'cloning a clone of the...'
Bit miffed there's no phaser or trem in this bargain range too, guess I'll have to stump up for Mooers!
Feedback
The 9mm pots have mismatched dials, the main pot had double sided sticky tape to hold it on, the flange had an extra spacer as the clearance for the jack sockets wasn't all that.. in terms of parts it looks really good, but I think I'll be selling the insides and putting a vero ocd in the enclosure
I have a vague feeling there were guts on TGP and the mooers seemed to be using (slightly) nicer parts. But I suspect they're much of a muchness, and as has been pointed out, it's a bit too much of a coincidence with the box the same, etc. etc. etc.
From what I saw, they're not quite as good as the Mooers. For instance, the Mooers had a packing piece behind the input/output jack so you could tighten the nut properly...these didn't. Also they'd designed the enclosure wrong and had to add a spacer in to prevent the innards fouling. Good enough for the money though.
Problem is I got my mooers for less than these ones
Where did you get your mooers for less than £20 out of interest?
eg crunchbox deep blue delay
Not sure how that makes me feel about them but at those prices, if I was looking for pedals I'd be tempted.
