Zoom g3. Educate me!
timmysofttimmysoft Frets: 1962
How good are the pedal drives? In particular, is there models for rat and boss sd1 and how good are they?
How do people find the zoom noise reduction?
«13
  • BidleyBidley Frets: 2959
    The drives range from rubbish to alright. I quite liked the Big Muff. You'll want to use your normal drive pedals. The noise reduction is great though, IMO.
  • bluechargeboybluechargeboy Frets: 1909
    Some of them are pretty good but they have way, WAY too much gain at the default setting. I have replicated the sound of my home-made TS808 very closely indeed. There are Rat and DS1 models IIRC. I haven't got the original pedals so dunno how close they are.
  • d8md8m Frets: 2434
    I found them all a bit 'meh' to be honest apart from the metal one.
    The preset values need some dialling down though.
  • ICBMICBM Frets: 74393
    edited May 2014
    I still haven't entirely been able to be happy with either the pedal models or the amps, despite a lot of fiddling. There's still something irritatingly artificial about them, even when dialing them in carefully to sound as close as possible to the real pedals - and as bluechargeboy says, they all have *far* too much gain at the stock settings. The amp models aren't even as good as the basic ones in Garageband either, which aren't brilliant themselves.
    It's odd, because the B3 sounds fine from out of the box.
    I like the G3 a lot for a lot of reasons, but the sound of the distortion modelling isn't one of them - or at least not yet.
  • thecolourboxthecolourbox Frets: 10362
    There's a boss overdrive on there but i think its an older one rather than the SD1, i quite liked that one, and the tubescreamer one. Ive only used the Rat, Muff and Fuzz Face (latter used in my fretboard challenge entry in fact), but to echo what the others say, they are too much gain unless you set them very carefully and selectively. I find if you use it with the amp models you need to set the amp gain pretty low and let the drives take care of it that way, otherwise i think it can sound a bit mushy-peas
    I'm scared and I'm waiting for life
    Not intending on using it for amp models, just pedal style dirt, reverb and delays
    The 'verbs, delays, mods and the looper are worth your money alone, IMO.
  • GrumpyrockerGrumpyrocker Frets: 4198
    I think the drives are pretty good - but the default gain settings are way too high. You have to turn them down quite a bit before judging them.
    I AB-ed the tubescreamer model next to a tubescreamer. And the mid hump sound was unmistakable. I've no qualms using it for jams or gigs.
  • fastboyfastboy Frets: 166
    I'm going to flog my G3 if you're interested (it's the one without the expression pedal). Excellent condition, boxed with manual.
  • monquixotemonquixote Frets: 18304
    The dirt pedals are alright ish as are the verbs.
    The mods and delays and looper are very good.
    The amp models are quite good, but don't react well to real OD pedals so you will have to use the simulated pedals if you want to boost them.
    how much!.
    They all seem to sell round the £80 mark delivered on Ebay so if there's no fees involved on my side i.e paypal gift or bank transfer I'll get it delivered to you for £75 if that sound fair enough?
    PM me if you want to go ahead.
  • close2uclose2u Frets: 997
    I quite like the 'Guvnor' effect choice for OD ... it works with my setup anyway.
    I don't use mega OD.
  • mike_lmike_l Frets: 5700
    edited May 2014
    I found the factory settings were way over the top, and there was quite a volume difference between the patches.
    Some are very good, some are crap. I liked the Van Halen one and the metal one best, but that's mostly what I'll play.
    I always found the drives/amp sims a bit uninspiring, or meh.
    The mods and delays were good though.
  • EdGripEdGrip Frets: 736
    The Muff is perfectly good, although it pales in comparison to my Musket (Muff type pedal). I also find the "Hot Box" (apparently based on the Matchless Hotbox) to be very useable, though, as everyone's said, you need to turn the gain down to almost nothing before it's useful. I'm not really fussed about this, as I enjoy having real distortion and fuzz pedals, so I'm always going to have them around to use with the G3 and whatever amp I've got.
  • chrispy108chrispy108 Frets: 2336
    I sold my SD1 because my Zoom did perfectly well at home levels.
    Noise reduction is great, much better than with a normal pedal, because you can put the noise gate last in the chain, but triggered from the guitar input, so it reacts really quickly, but still cuts noise from pedals/amps.
  • DrBobDrBob Frets: 3042
    I use mine on a simplified pedal board. I still have a separate drive pedal 'du jour', TC Spark Boost, Dunlop CAE 404 Wah. Everything else comes from the G3..
    Perhaps it lacks some of the nuance of nice individual pedals but out in the real world it works really well
  • DiscoStuDiscoStu Frets: 5731
    I scored a G3X on eBay last night!
    I want it for modulation and the looper, mostly.
  • p90foolp90fool Frets: 32371
    The drives are ok, but are lifted into a different league if you put a virtual graphic EQ in the chain. Same goes for the amp models btw.
    Usual rules apply as with all multi-FX, turn the overall volume up and everything else waaay down.
