I bought a tempest custom at Christmas. Since then it has been playing up every now and then with the neck pickup producing very low output after switching from the bridge. Trouble is the happens only every 2 hoursl or so. I took it back to the shop and spent ages showing them. They sent it back for repair but after 8 weeks I get it back, but still the problem persists... Is this a common schecter problem? I like the guitar but am now not trusting the brand, would I be better off getting the shop to exchange it for something else?
Is it passive pups with a coil tap ?
could also be the switch ?
what work was carried out on it ? and can you get a cavity shot to stick up here?
I had a problem with a micro switch not so long ago. They are fortunatley very cheap to replace.
I did clean the switch.. It did not help in this case...
Cleaning the switch with contact cleaner doesn't always work. You may have to draw a piece of folded fine sandpaper through the switch contacts if it's corroded rather than dirty. If that's not it, it could be the volume pot. Even though it seems to be set off by using the switch, the vibration that causes through the guitar body can sometimes do strange things.
Good to know that this looks like a one off problem and not a general Shecter problem, I really like the guitar so will take it back tomorrow and see what they say...
