Also did you update the firmware.
The original mustang had lovely cleans, but all the distorted amp models were utter shit and it hated pedals.
The distorted sounds need time to dial in. Taking the noise gate off, playing with different cabs, bringing the gain down and the volume on you're guitar helps a lot. It's definitely better at cleans and overdriven.
I think I just need to experiment with the order in which the amp and app pair /connect, because when it throws a tantrum it tells me it needs a firmware update (it definitely doesn't, I'm current), but when it's connected properly everything is fine and it works well.
If you don't have two, try forgetingbthe one for music streaming a d the connect to the amp through the app.
The good:
- The app is great and very easy to use.
- Everything can be very easily controlled from your phone or tablet. FX can be moved around the chain easily.
- Bluetooth streaming of backing tracks is superb.
- There are definitely some surprisingly good clean tones. It's not a tube amp but I'd say an 8 out of 10. The Fender models and the mk2c model in particular.
- The Klon model is actually pretty decent.
- accept it for what it is (a practise amp) and the features make a decent case for it
- there's a decent range of fx and they all sound pretty good, at least at first glance.
The bad:
- Distorted tones are full-on modeller fizz. Couldn't find a decent one, although the jubillee model showed some promise with the right cab. It's going to take some time to dial those in.
- It can sound boxy, especially with the wrong model.
- Not many of the drives / fuzzes were convincing.
Compared to my 'proper' modeller (Amplifire) the Mustang cleans were good. But the Amplifire is in a completely different league on the gainy stuff.
The jury is still out....
I'm going to see what downloads are available. I noticed that Fender have posted a lot of song specific presets themselves for the Fender Play lessons and they've got quite a few of my favorite artists on there.
Then I may tweak from there. There are 3 issues to address:
1. Tame the fizz - will probably reduce the gain and have a play with tone stacks and EQ.
2. Make the decay more natural and harmonic - probably gain and noise gate reduction.
3. Minimise boxiness - I'd guess by EQ'ing.
Not sure which model to start with but the Jubillee struck me as as good a place as any. Also intrigued by the Supersonic as Fender have done a decent job of modelling their own amps. This video explains why...
Cranked Marshall Plexi like tones?
Will check number of connections next time I use it, but yes, my Vox had two, one for each purpose, so that makes sense.
My footswitch turned up today so been busy playing with that.
I think there are some decent gain tones after some tweaking, but haven't experimented enough yet with EQ and cabs to find favourites for my own presets.
So far, though, the Orange sounds decent enough to me, and the Mesa iiC, whereas the Jubilee for example I find unusable. Too much fizz and shrill high end, but hopefully that can be dialled out - I think it's just a case of spending some time with it, plus of course it's all subjective and I don't have real life experience of most of the amps it is modelling.
For fun practice at home I think it's good for the low price point.
This is another point with modeling, it's almost too easy just the switch between akps without understanding them fully. If you had just one tube amp, you'd spend the first few days with it, trying to dial it in. With modeling you just move on after 20 seconds, if you can't do it.
I thought I'd got to a decent place so then I A/B'd it vs my Amplifire / Laney IRT-X.
The cleans on the Mustang held up very well. I would say that some of them (e.g. Mk2C, Princeton, Twin) were better than the closest equivalent models in the Amplifire*. But on Plexi, Marshall and Friedman models the Amplifire sounded much more alive and present, whereas the Mustang still sounded a dull and boxy in comparison. On all models the Amplifire also felt much more 'organic' and responsive, whereas the Mustang felt a bit flat. Perhaps this is unfair as the Amplifire and Laney would be 3-4 times more expensive. FWIW the IRT-x only has an 8" speaker and compression driver so it's not chalk and cheese in terms of speaker size.
As to the Mustang itself - the cleans are very good, as is the bluetooth streaming. The app makes arranging the signal flow / pedals a complete doddle and the range of effects is good. It works like you would want a modelling amp to work in 2020 and instantly makes the Amplifire UI feel like its from a completely different era. But if I can't get the dirtier tones to work better for me then I may be sending it back :-(
For now the jury remains out.
* I'd always thought the Amplfire was 'quite' rather than 'very' good at clean tones and that has been confirmed again.
There are plenty of other pedals sitting there, rarely used.
And then I kinda forgive the GT40 its relative deficiencies and settle down to enjoy it's benefits
Couldn't stop playing it last night.
...and yes, at under £200 it is incredible value for money.
