I have had a number of Count To 5s, but as they were selling for a reduced price, I thought I'd give Montreal Assembly's 856 for Zellersasn a go. (The £60 I had to pay for import duties was a bit painful though)
The name comes from a torn label found on a box when they moved into a new unit, apparently.
As usual with MA, it arrived in an unbranded box with nothing more than a bit of bubble wrap, no manual, no stickers.
There's a manual on the website, but no specific indication as to how to connect it up so it took two goes to get a signal, again, nothing new there
I tried prodding buttons and twiddling knobs at random, which enough to convince me that, a bit like my first play with the Blooper, I'm going to have to read the manual before I have any chance of getting much out of it
I've currently got it connected up just before the Blooper in my chain, but once I get a bit more of an idea of what it can do I might move it around a bit.
"I'll probably be in the bins at Newport Pagnell services." fretmeister
It is a (possibly over-complicated, only time will tell) looper.
As you can see by the manual, some of it is fairly straight forward, some of it is a bit more random. .
http://mtlasm.blogspot.com/p/856-for-zellersasn-firmware-update.html
As with a lot of what I buy, if you play in a covers band, or a blues band, or pretty much most bands, it's probably not for you.
If you like making weird noises with only a vague idea of what you're doing most of the time, then it's ideal
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
