NPD: 856 for Zellersasn
Paul_CPaul_C Frets: 7810
I have had a number of Count To 5s, but as they were selling for a reduced price, I thought I'd give Montreal Assembly's 856 for Zellersasn a go. (The £60 I had to pay for import duties was a bit painful though)
The name comes from a torn label found on a box when they moved into a new unit, apparently.
As usual with MA, it arrived in an unbranded box with nothing more than a bit of bubble wrap, no manual, no stickers.
There's a manual on the website, but no specific indication as to how to connect it up so it took two goes to get a signal, again, nothing new there ;)
I tried prodding buttons and twiddling knobs at random, which enough to convince me that, a bit like my first play with the Blooper, I'm going to have to read the manual before I have any chance of getting much out of it :)
I've currently got it connected up just before the Blooper in my chain, but once I get a bit more of an idea of what it can do I might move it around a bit.
https4bpblogspotcom-d1lS1A6X2igW_90ptW2olIAAAAAAAAGDkR--CbKe9NvocmZtZbNDvwRYh-cp0-klvgCLcBGAss640286884-683a860643e9415ab3f8874861b12219jpeg
  • BintyTwanger77BintyTwanger77 Frets: 2233
    edited September 2020
    What does it do? Is it a hyper-complicated looper?
  • SassafrasSassafras Frets: 30301
    That all looks very logical and super intuitive.
    Any pedal that has a UI that looks like the controls for a Soviet-era nuclear reactor just screams "user-friendly", doesn't it?
  • Paul_CPaul_C Frets: 7810
    It is a (possibly over-complicated, only time will tell) looper.
    As you can see by the manual, some of it is fairly straight forward, some of it is a bit more random. .
    http://mtlasm.blogspot.com/p/856-for-zellersasn-firmware-update.html
    As with a lot of what I buy, if you play in a covers band, or a blues band, or pretty much most bands, it's probably not for you.
    If you like making weird noises with only a vague idea of what you're doing most of the time, then it's ideal :)
    I like doing both and everything in between, pretty much.
  • soma1975soma1975 Frets: 6727
    Needs a couple of Farndurk pedals either side of it to finish off the aesthetic.
