I'll see if I can source a cheap used one and maybe a cheap used bd-2 and compare. I always liked the Digitech screaming blues pedal, so if that's similar to the bd-2 it's a possible winner.
Stick another good buffer after the OD-3, or a clean boost. Both should bring back enough sparkle to your signal
I looked at the circuit of the BD-2 when I modded one - interesting, as they basically built an opamp out of discrete components. I think there might have been more than one clipping stage as well (including to ground as opposed in a feedback loop, I dunno).
It would make more sense then that the SD-1 has the OD-1 DNA i.e. an opamp chip with clipping diodes in the feedback loop. It would also explain why it's cheaper to make than the OD-3
It does a great transparent overdriven sound, I couldn't crank the amp as the kids were asleep so it's not really pushing the amp, its' gain is up higher to generate it's own dirt. Tone control is very wide ranging, I set it typically to about 1 o'clock which is quite good for a decent rock sound. maximum gain is much less than my BD-2, but thats' been modded by myself many years ago and I can't recall if I changed the gain on it ! It's also notably different from the BD-2, that pedal is definately voiced differently, like a Fender type mid cut I think.
With the gain low is it has a good clean / slightly overdriven when you dig in feel to it. responds very well when you play light or really dig into the strings, very responsive and uncomprssed. . Bass is a little cut for my liking I coudl probably do with modding a capaitor to get a little more low end through.
Gain up at max (or close to it) and I was getting some decent rock riffs going, tone control didn't need adjusting from where I had it set at low gain.
I think it will certainly be coming back onto the board and kicking the BD-2 off for a while.
http://i123.photobucket.com/albums/o307/blackscience/PB170714_zps3b6b549a.jpg
