nine's
HootsmonHootsmon Frets: 16311
Probably they should but do they?
For teh users of both 9s and 10s on their guitars.........do the nines break more easily/often?
tae be or not tae be
  • I don't think so personally. Not had many cases of string breakage. 9's are under less tension at the same pitch as 10's so I don't think it makes much difference what gauge you are using.
    Breakages are normally caused by binding at the tuning peg or bridge. Very rarely the string itself.
  • No - but I don’t have a heavy right hand. I bend ‘a lot’ and can’t remember when I last broke a string.
  • SassafrasSassafras Frets: 30358
    No.
    Only thing I don't like about 9s is they're too bendy.
  • I break 9s and 10s about as often as each other, if that helps but I'm a recent convert to 9s on the whole.
    9s on Strat/Tele Fender scale. 10s on 335 and Les Paul. Thinking of going 9s on the Gibson-y ones as well but I'd expect that to be too sloppy. Maybe 9.5s  =)
  • I had a D string on a set of 9s break once. It went with such a bang that initially I thought the bridge had snapped.
  • duotoneduotone Frets: 1065
    Try 9-46, they feel good to me
  • mgawmgaw Frets: 5529
    nope
  • rze99rze99 Frets: 2504
    9-46 on a Tele and Strat feel rigght to me 10-46 on gibbos and all others
  • ICBMICBM Frets: 74475
    Standard sets of 9s feel weird to me because the B is too light (11, should be a 12) and the G is too heavy (16, should be a 15). I’ve never understood why they’re like that.
  • HAL9000HAL9000 Frets: 10072
    I use 9s on most of my guitars with no issues. Last two strings I actually remember breaking were both 10s but that turned out to due to be a rough spot on a bridge saddle - I almost never break strings so two high Es in quick succession on the same guitar raised my suspicions.
  • SteveRobinsonSteveRobinson Frets: 7343
    edited September 2020 tFB Trader
    D'Addario balanced tension string sets are the solution.
    Agreed. Been using the XL120BT for about a year and they are perfect
  • I just play 9-46 on everything and try to get better at playing the thing, rather than agonising on this kind of stuff.
    * Hamer SS2 & T62
    * Music Man Luke 1
    Please drop me a message.
  • I doubt that the delicate girly hands of a player that chooses to use 9's, would have the strength to actually break a string, so I reckon it should be fine.
    11reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • I've used 9s for 30 years.  Rarely break if ever.
  • robertyroberty Frets: 10932
    Some of those girly hands make a lot of money
    Absolutely. There will always be a market for hand-jobs.
    12reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • DLMDLM Frets: 2530
    Yes, nines break more often. Unless gigging[1], I play through my high E strings. They break from fatigue where they have abraded over a fret. Tens are a bit thicker, the same process takes slightly longer, and I can do more two-tone bends on the high E before it pings.
    [1]:cry:
  • sweepysweepy Frets: 4268
    I settled on 9.5’s, yes, I am that awkward
  • Nines here, I break em occasionally but I bend the fuck out of them sometimes
