Whammy bar wobble
JazzthatJazzthat Frets: 163
Why can't they make a proper fit to stop whammy bar wobble ?
I find it a very frustrating paying £145 ( in this case Babicz bridge ) and have wobbly whammy bar on it , like on cheap Chinese crap .
I read few threads and it affects fender bridges etc .
Why wouldn't they use tight thread tolerances like 4H or 5H to fit these things together like they should ???
Really frustrating !
  • dazzajldazzajl Frets: 6232
    That tiny little click feeling drives me nuts. It’s there on most screw or push in arms I’ve used. Give me a good Bigsby or a Duesenberg trem
    any day.
  • stickyfiddlestickyfiddle Frets: 28752
    Callaham fixed this 20+ years ago, and they sound great too. I won't buy any other sort of strat bridge ever again
  • JazzthatJazzthat Frets: 163
    The thing is , I wanted a tremolo bridge in black with narrow spacing to fit Pacifica and I had a very limited choice .
    I am literally pissed off , that in 21st century they can't make a damn whammy bar stay in place in any position without wobble .
    It's just ridiculous and it defeats its purpose !
  • KittyfriskKittyfrisk Frets: 20598
    Have you tried a few wraps of teflon plumber's tape around the tremolo arm bush end?
    Not yet , but I am aware of this hack .
    I am more debating whether to get in touch with thomman ,where I purchased it from , or this is how they make/ sale these bridges and I need to put up with it .
    Fair point. If you don't get help from Thomann you might get in touch with Babicz direct?
    I think I'll pass on Babicz customer service .
    When I purchased the bridge the supplied screw had kind of bad finish .
    So I contacted them and they had promised to send them in . 2 months later , there was still  no sight of  screws and communication has pretty much ended .
    Thomann on the other hand were awesome to deal with and that had got sorted .
    This is my first tremolo guitar so I am curious , if this is supposed to be like that with this particular bridge ?
  • BowksBowks Frets: 446
    Get some of the tiny trem springs Fender use in their trems and drop one in the hole for the arm, fixed my wobbly woes.
  • BlueStratBlueStrat Frets: 1018
    Agree 100%, that little jiggle in the arm drives me mad too.
    Such a simple fix, why do they still make them like that?
    Also the amount of force you need to use to push in a fender pop in arm, it doesn’t pop in at all you have to punch it in there. Why not use a correctly tensioned clip in the first place?
  • Philly_QPhilly_Q Frets: 25106
    I'm surprised something as over-engineered as the Babicz bridge hasn't included a cure for this particular issue.
    The Delrin/Teflon sleeves used by PRS and Callaham seem to be the best solution.
  • tone1tone1 Frets: 5320
    PTFE tape for me.... :)
  • The best solution I've found for a standard Fender trem is a short piece of plastic tubing pressing up against the saddle - which has the added bonus of the arm staying where you put it.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • jonnyburgojonnyburgo Frets: 12660
    I thought a trem was supposed to wobble ;)
    "OUR TOSSPOT"
    So this is basically an ongoing crap design across various brands ...
    When I get some time over the weekend I'll see if there's a tiny space to accommodate some plastic washer and or use PTFE tape .
    Or try a very small 'O' ring on your end. Ooh err, missus!... but worth a try.
    That's the plan :) thanks
  • I always fit the Floyd Rose push-in arms on my guitars, they're so much better than any screw-in one that I've used... not much good for non FR trems though, of course
  • ICBMICBM Frets: 74493
    That’s neat. My solution was to remove the block and drill out the top of the hole enough to fit a rubber grommet that grips the arm, but it’s not 100% effective. I’ll give that a try as well...
  • axisusaxisus Frets: 28397
    Personally I need a stiff one [insert Matron joke here] so I gravitate to trems where there is built in adjustment. I've done the plumber's tape trick in the past. Works well but you do have to redo it every so often.
