Side dot markers stickers
TeleMasterTeleMaster Frets: 10591
A new tele I have has very faint side dot markers. I struggle to see them when at practice, where we have low lighting.
I found some small circular stickers to replace or add dot markers, but nothing too suitable in the UK.  Has anyone got any issues of what I can use?
  • I’ve bought inlay stickers and body decals from here before:
    https://www.inlaystickers.com/
    Not sure if they do side markers as well though. If not, presumably any small vinyl stickers would be ok? Something like the sheets they sell in Paperchase/Poundland etc?
  • I’ve never known a good guitar teacher to recommend using Neck  side dot markers.
  • The best Decals are Captain Beefhart. :/
  • TeleMasterTeleMaster Frets: 10591
    Thanks. They're in America, I found some in the UK but they're maybe a bit big.
    edited November 2020
    I've been playing 25 years now. I want some visible side dots to help orientate me from time to time on a really dark stage so I'll use some side dots. Even people who say don't use them probably use them sub consciously, I don't really care what 'good teachers' recommend. Most teachers I've used have said that there are no rules, and if it works there's no harm in using it. Thanks.
    0reaction image LOL 0reaction image Wow! 9reaction image Wisdom
  • NiteflyNitefly Frets: 5069
    I imagine stickers would peel off eventually - what about enamel paint as used by model aircraft types?  Bright yellow should be OK.
  • TeflonTeflon Frets: 229
    Why not go the whole hog and get some LEDs installed http://www.simscustom.com/html/00leds.htm.  I've seen a guitar with these fitted in the side of the neck, and when switched off, you'd never know they weren't standard side dots.  A very subtle mod if you're into that sort of thing.
    Cliff
  • KittyfriskKittyfrisk Frets: 20600
    There was a discussion on this topic a while back
    https://www.thefretboard.co.uk/discussion/comment/2699211/#Comment_2699211
    Would that cause any harm to the finish?
    Cliff
    A bit extreme for a 53 Tele reissue! Lol
    https://www.ebay.co.uk/itm/303074476595
    These seem decent. Although slightly larger than normal side dots.
  • RolandRoland Frets: 9129
    Stickers do wear off, and they can leave a sticky residue. I tried Humbrol white enamel paint, but that wore off too. I had more luck with a silver marker pen. If the guitar I question hadn’t been a Parker Fly I’d have drilled for new markers.
    Talking of markers. I bought some Lumilay to solve a similar problem, but haven’t fitted it yet. The urgency evaporated because I can’t test it under gig conditions.
    Dunno, sorry, but I suppose it would depend on what the finish actually is.  I can't see it having much impact on poly, but an oiled finish might be a problem.
    It's a nitro finish.
    Hmm, maybe try acrylic instead of enamel then, they are water-based:
    https://www.humbrol.com/uk-en/shop/paints/acrylic-paints/99-lemon-matt-12ml-acrylic-paint.html
  • SassafrasSassafras Frets: 30358
    Get the coarsest file you can find and file the fretboard edges down between the side dots so they stick out.
    Rely on your sense of touch more than your eyesight.
  • dariusdarius Frets: 689
    I can't give stickers advice but +1 for installing Luminlay side dots. Done by a tech, they are a game changer for dark gigs. (Those were the days).
    And I do hope @Sassafras is joking. :-)
    How much did that cost you? And yea, I'm not gonna go to a Custom Shop with a file lol. I'll leave the work to someone else!
  • rossirossi Frets: 1741
    I would drill a small shallow hole and fill with paint .I use Tamiya .Its a resin based water soluable  until dry paint and high quality . .Use a decent  fine brush from a proper art  dealer or model shop not a cheapie as it will have a proper point .If carefull you should just get it right and not need to remove any excess.I use Tamiya clear gloss too and any clear laquer small chips as it is similar in  actual texture and appearance  to nitro and poly  clear .A touch of clear orange added to it matches a tinted clear on necks ..
    If you want to go anal then drill out and insert brass rod  then file down and polish .
  • I was about to say something similar to rossi.
