I've taken up guitar lessons again after a break of 35 years (!). I still have my old Yamaha FG-180, which sounds beautiful but is in a bit of a state. The nut has worn away: a couple of the strings are seated in bits of paper in the nut to stop them buzzing but there's still buzzing.
I was wondering whether it would be cost-effective to have the nut replaced on such an old guitar? I understand that it's a bit of a classic of its genre, but have no idea how much I'd expect to pay for the work.
Can anyone offer any advice or guidance on the likely cost of this sort of work? I'm based in Richmond (West London).
TIA for any feedback.
Definitely worth getting the work done.
I'd expect it to cost around £40, plus strings.
With the right tools (you need specialist files to shape the string slots properly) - it is a job you could tackle yourself - though there is plenty of opportunity to mess things up, particularly removing the old nut without damaging the guitar.
Getting a pro to do it is money well spent.
That said - I'd far rather pay a bit more for a good job than save a few quid and have my guitar messed up.
Hi itm - I see you're in Richmond. Not too far from Ripon, where Jim Fleeting will do you a great job. He never tries to do too much to your guitar (ie he won't talk you into spending more than you need to), and is a top bloke. I have no connection, apart from being a happy customer
http://jimfleetingguitars.com
Really nice bloke. Also, you'd be able to check out his line of rather nice amplifiers while you're there.
It was a few years ago but the last time I got Jon Dickinson the make and fit a new nut on my Ibanez cost me £25 if I remember correctly. I always tell him to save time and money on the full setup (I can do that myself) which keeps the price down, but I'm sure it wouldn't set you back £100 with Jon or another smaller concern. Charlie Chandler's do charge top whack.
Jon's at Antenna Studios in Crystal Palace (links in my original post). I highly recommend checking out his aluminium-shelled amps.
I would expect to pay £30-40 tops, that includes the nut. If they're not wrecked, you could get away with keeping the current strings. A set up probably wouldn't be required. Guess it depends on what you're going to be playing, but Acoustics generally have much higher action that electrics, so you shouldn't need a fret level. Every Yamaha I've played has had a good bridge height (especially old Japanese ones like yours), so really the only other thing that could be required would be an adjustment of the truss rod to either add more or less relief to the neck. Not £100 of work there.
Just goggle your local luthiers, or check the sticky thread in set up on this forum to find people in your area.
Happy strumming.
