Hi all
I'm trying to record me singing and playing the keyboard at the same time. The mic is picking up the thump of the keys and it's not great.
Any ideas how to stop this? The mic is on a stand, on a boom positioned so the mic is in front of the keyboard but it is still picking it up.
The dynamic mic gives quite a deep noise, my new condenser gives a higher pitched clicking noise. I have a reverb and comp on the vocal effects so it's making the vocals sounds terrible with big bassy booms or higher clicking noises through the comp and reverb.
Google searching this seems to only give results about computer keyboard, not the digital piano type.
I am playing a Christmas event via zoom in December hence the need to do both simultaneously.
Any tips? Can I use one of those plastic vocal shield things but underneath the mic instead of behind it as you'd normally do it? Would be a bit visually awkward on camera but was just an idea
Any ideas welcome!
soundcloud.com/thecolourbox-1
seriously if you sing directly into a dynamic mic you will get very little key clatter unless you go apeshit with the compression. I would shoot for no more than around 4dB gain reduction with a medium attack and see how that is
what dynamic mic are you using? How much gain have you got on the preamp?
The comments re compression and gain etc - I don't know, it's the TC Helicon Voicelive and there are auto tone settings that add some compression. The gain might be a bit high but the output is really quiet, which is fine when recording obviously but I need it to be loud enough for the zoom thing. When I did a practice earlier with my mom and dad via zoom they said it was really too quiet.
I thought of using the Voicelive as the interface but that seems more problems than its worth getting it to work lol and it turns out I can't make that any louder anyway so it's kind of moot.
I turned the input gain on the Voicelive and the clutter noise was obviously less (back to using the dynamic mic again for now considering folks say that should be better) but then the recording was so quiet it would be useless. Would I be better upping the input gain on the audio interface ie after the vocal effects rather than the input gain on the Voicelive presumably?
Maybe if I encircle the mic in foam I could decorate it Christmas style
Ideally a mic for vocals, Di the keyboard and listen through headphones.
God knows. I really hate music sometimes.
My interface is shit but I'm not sure I want to go out and buy one with enough inputs for what I'd like, only to find I still have the same problem as usually that's how things go for me
