Ahem. Sorry about that, sacrilegious thing.
Singlecut or doublecut?
Careful you don't weaken the neck joint too much, if it's the latter.
Single or double-cut?
What type of pickup do you want to fit?
Where do you want the switch?
Two knobs or four?
Or try an EQ pedal. Not the same obviously, but you might be able to get closer than you expect to an approximation of it.
I know I could get a les paul special but it would mean putting this up again.for trade and tbh I'm cutting down on that faf now it's too much hard work, so I thought it would be best to look at modifying this as it's not paticually desirable it's a 2007
@ICBM I'd be happy with another p90 or a single coil, knobs would be the same and the switch next to the knobs thankyou your reply is appreciated
If you can accept a switch in between the knobs - maybe a mini-toggle, although a full-size one should just fit - then that reduces the work considerably.
1980 Tokai LS-80
The trickiest part of the job is drilling a wiring hole for the pickup, but you can do it with an extra-long bit via the jack hole, which is how Gibson did the Specials.
get a slightly modified pickguard made that still fits in the same screw holes or that any holes you make for it will be covered by the original. That’s easy £30 job
get a humbucker or a single coils sized humbucker or at a push a very high output single oil pickup. A p90 will be too long and make the pickguard huge to cover it.
