One amp to rule them all - for blues / rock home use and jamming only
Broseley_BobBroseley_Bob Frets: 34
I am looking for one amp for the above. I won’t be playing gigs, just me at home or with a mate. Mostly in the house but he has a large barn we can use.
I am not a swapper of gear so this is a long term investment.
It needs to be reliable and easy to fix. I also like simple, I don’t need it to replicate every sound ever made. Just be great at what it does.
I have something in mind but would like to see what what others think before I disclose what it is.
I like value for money, which does not mean it has to be cheap.
I will be using a Gibson LP.
Thanks in advance.
«13
  • russpmrusspm Frets: 445
    edited July 2021
    Lots to go at but.... if you like simple then a Lazy J10 or J20 would be a great investment. There is a great YouTube video of a Gibson LP gold top into a Lazy J10. No effects just guitar and amp.
  • munckeemunckee Frets: 12403
    What you mean is you weren’t a swapper of gear before you joined…. : )
    3reaction image LOL 0reaction image Wow! 5reaction image Wisdom
  • p90foolp90fool Frets: 31629
    A JTM45 with a 2x12 cab and a couple of pedals.
    It will cover any style the way a master volume amp won't, and will outlive you.
  • lovestrat74lovestrat74 Frets: 2530
    One of the new Supro delta king amps
  • tone1tone1 Frets: 5175
    Cornell Romany Plus/12 with Reverb
  • Tonemaster Deluxe Reverb. Built in attenuator (basically master volume simulator) so you can have it quiet at home if needed but keep majority of your sound. Gets plenty loud enough to gig if needed so barn wise should play nice. Lightweight so easy to transport.
  • thebreezethebreeze Frets: 2806
    Shameless plug, but it would fit your needs very nicely:
    https://www.thefretboard.co.uk/discussion/209378/fs-1964-vox-jmi-ac10-twin#latest
  • OssyrocksOssyrocks Frets: 1673
    Tweed Deluxe 5E3 clone. Job done.
  • GrumpyrockerGrumpyrocker Frets: 4145
    edited July 2021
    Laneys are always worth a look. The Cubs and Supercubs sound great.
  • ChuffolaChuffola Frets: 2026
    Stock answer from me these days - Roland Blues Cube Hot. Perfect for home and can get as loud as you need for jams. It’s a Tweed style so perfect for your needs
    Katana
  • The amp I am thinking of is the Lazy J10 or J20.
    I was considering a Marshall sv20h with 212 cab but think the Lazy J would be better.
    Thanks for the input.
  • Broseley_BobBroseley_Bob Frets: 34
    edited July 2021
    Views?
  • dazzajldazzajl Frets: 5775
    One considerable bonus of a Jazy Lay is that if you buy used they hold their price as well anything on the market. There are so many amps based on or around the Tweed Deluxe, that it might be worth at least a quick trip down the rabbit hole before making a final decision.
    Views?
    They sound glorious and hold their value. You can just plug in without pedals and lose hours.
    They also take pedals well and the onboard VAC is great for home playing.
    it’s a class amp without doubt and may save you from chopping and changing. If you are in the North West you are welcome to come and try mine.
  • jonnyburgojonnyburgo Frets: 12384
    Bandit and some peggles, chuck it in the van year after year and don't worry about anything.
    "OUR TOSSPOT"
  • midiman1962midiman1962 Frets: 102
    Katana
    +1 for the Katana - very impressed by the basic mk2 at all power levels
  • rlwrlw Frets: 4716
    Save squillions over any valve amp and it's brilliant quiet, loud and in the middle.  Oh, and you can carry it too.
  • monquixotemonquixote Frets: 17648
    What is your budget and what sort of sounds do you like?
    There is no point in suggesting an ac15 if you want a jcm800 sound.
    I would suggest the suggestions of katana, or tonemaster don't fit the bill of simple and easy to fix.
    If you want Marshall the DSLs are superb and great value. If that's too complex the mini Plexi and JCM 800s are both meant to be awesome.
    If you want more of a fender clean then you can't go wrong with an HRD.
    If you want to get more spendy then get Rift to make you something. You could buy that in whatever flavour, know you had the best and it would outlive you.
  • De_BatzDe_Batz Frets: 117
    Romany will hold its own against any amp in the category of small, home use amps. Having said that, the one I had (early Romany with plexi panel, only two power modes, P10R) was capable of keeping up at a gig as well as sounding good at home. It's not a big, boomy headroom-y clean, of course. In fact, with the P10R it's all a bit ragged turned up. But gloriously ragged...
