BOSS SD1 Super Overdrive. Good or Not?
markjmarkj Frets: 914
Just read Adam Goldsmiths column in the latest issue of Guitarist magazine and he highly praises the SD1, he says that it easily holds its own against high end boutique pedals. They’re relatively cheap new and there’s a lot of bargain ones on EBay. What’s the verdict of Forum members?
«13
  • SupportactSupportact Frets: 955
    I used one for ages and they're great. It does have a specific eq it adds which really cuts through in a mix. You might like that effect, or not. As you say, cheap enough so no problem to buy a used one and give it a go.
  • CirrusCirrus Frets: 8491
    Good
  • I’ve used one as a boost into Marshall (and Marshall style) amps and it does its thing - which you might or might not like.
    I liked it for what I was trying to achieve but, as mentioned, cheap enough to try and see I guess.
  • markjmarkj Frets: 914
    Would it suit Fender amps?
    Are they warm sounding or shrill?
    They cut a bit of bass, which is great for tightening up an overdriven tone. There is a tone control, so if you use that you can match it to the amp. I find there's a spot where it cuts through but is not shrill. Quite a lot of reviews on YouTube you could check, if I had to describe it I'd say it was just a nice crunchy typical rock sound. Also classic way of using it to turn the gain down and use it to boost a valve amp.
    Get one.
    It's a classic and shits on a lot of booteeky pedals.
  • monquixotemonquixote Frets: 17609
    An SD-1 into a JCM800 accounts for the guitar sound on about 50% of classic metal records.
    It's very close to a TS so if you like one you will probably like the other. For whatever reason you seem to get more Fender + TS and Marshall + SD1, but either way should work.
  • RickLucasRickLucas Frets: 404
    Buy one. Try it. If you like it, keep it.
  • webrthomsonwebrthomson Frets: 1031
    Sassafras said:
    Get one.
    ^ This is the truth, get one you wont regret it :)
  • StratavariousStratavarious Frets: 3673
    Prefer the OD3... but it is a classic
  • ICBMICBM Frets: 72357
    Great. One of the classic overdrive pedals, broadly in the 'Tube Screamer family', but slightly differently voiced and which seems to work extra well with Marshall-type amps. (Although fine with Fender and other types too.)
    It has one slight fault - when the drive control is set fairly high (usually above about 1 o'clock), distortion leaks into the bypass signal. How much varies from one example to another, but it's always present to some degree unless you run the SD-1 after another buffered pedal, which suppresses it. It's only noticeable if you use a perfectly clean amp sound though.
    Anyone had experience with the Waza version?
    I'm planning to get one to complete my set :)
  • guitartangoguitartango Frets: 1020
    If it's good enough for Mr Gilmour, then it's good enough for you :)
    “Ken sent me.”
  • polotskapolotska Frets: 116
    Yes. I haven’t tried them side-by-side, but I thought the SD-1W’s Custom mode was a bit better than the Standard mode—mostly I think it has more bass. The SD-1W does also fix the distortion-leaking-into-bypass issue that ICBM mentioned above.
  • WhitecatWhitecat Frets: 5423
    ^^ this - the Waza version would be my preferred buy 100% of the time unless you are on some super tight unexpandable budget.
    That said, agree with others that it's still a classic pedal with "a sound". I think it's one of the like three pedals total Lindsey Buckingham has on his board, right? If that's not a pretty good argument for it I dunno what is.
  • TINMAN82TINMAN82 Frets: 1846
    Indeed. Crazy he pretty much just used off the shelf boss and EHX pedals as his core tone for most of the 80s/ 90s. It’s probably a good message for the rest of us!
  • RedlesterRedlester Frets: 1072
    Yes, the SD-1 is an absolute classic.
    I haven't tried the Waza, but TBH I think the fact that the standard model cuts out some of the bass is a large part of the magic you get with the LP>SD-1>Marshall set up.
    I love this pedal.
  • JezWyndJezWynd Frets: 6062
    Brilliant pedal and now available in fetching black colour scheme...
