So.... GAS took a hold of me and i ended up doing buy now pay later on a brown eye! i actually got it yesterday but ive only had chance to try it at a low volume thus far. seems to sound pretty great at very low volume volume but its nothing mind blowing. im sure though when i crank it at tonights gig i will be suitably impressed.....well i hope anyway! LOL.
the craftsmanship is excellent as you would expect from an amp of this value. looks stunning.
to past and present BE owners, what speakers have you/do you run with the amp?
im using v30's in a fatboy cab at the moment, but ive had thoughts about v30/creamback mix prior to getting this amp.
I tried the greenback / V30 mix in a Mills Acoustics Mach 212B and found that the V30 somewhat dominated the greenback - not necessarily louder but much more prominent.
So I put another greenback in there and it sounds fantastic with the smallbox.
A little looser and really brings the plexi channel to life. :-)
Not sure if that's correct, but that would make a 412 with 2 V30's and 2 greenbacks still only 100w rating wouldn't it?
