Can you get more of a classic rock tone out of it? All the demos seem to be seriously high gain chugging.
Does it cut through live okay?
Ive been using the new DSL100HR head with a 1960A cab for gigs lately- really enjoying using it- plenty of versatility if you want the Marshall tones. It even had a 50watt setting, can’t go wrong with that-cheap as chips too! (Best with the 6 way foot switch though)
All of the demos seem to be based towards high-gain chug which is under-selling the amp IMO.
I need to try a 100 if Rockmonster's comments above are anything to go by too..
Seriously impressed with the EVH - it was a bit of gamble buying one without really hearing one in the flesh but its a gamble that's certainly paid off.
Live - if you can't cut through enough with what's on tap from both a volume and EQ perspective then you either need to sack the rest of the band for being too loud or there is something really wrong with the amp!! - I can easily drown out the rest of my 5 piece if I wanted to - actually, last gig before xmas there was an issue with my channel through the PA - we had to end up with me just running backline whilst the rest were through the PA - not an issue at all - had volume to spare.
In actual fact I just purchased a Friedman BE OD Deluxe pedal to use with my HRD. Wow!!! This thing is insane!!! Need to test at volume with the band to really see how good it is but so far so good.
