I have terrible trouble following a metronome, so I'm looking for help, tips and advice.
My timing isn't bad but it's not as good as I would like obviously, I waver a little. If I have a metronome running I lose the click/beat/tap (i've tried loads) pretty quickly, it fades to the back and I stop following it, I do follow the visual part but (and its a big but) thats not much use if I ever end up in a band/jam. I've just recieved a Soundbrenner Pulse and that seems like a better idea but I'm not sure its actually powerful enough, although I've only tried it on my wrist and upper arm so far(only had it on the 24th)
Anybody got anything to batter my subconscious into submission and play the game ?
ta
I often play along to a loop using Steven Slate Drums.
Just because you're paranoid, don't mean they're not after youIf playing to a record helps then try something like GarageBand to provide drums and bass.
Start at a moderate pace (70-80bpm is good) and play scales, initially 8th notes (two notes for every one click), but also try quarter notes and 16th notes.
Perhaps I need to go back to basics as far as the metronome goes and lock in simple strumming with it and slowly expand from there. It's my own fault for glossing over the metronome training early on. Maybe just knuckle down and concentrate.
Also, something that really helped my time is to run scales and arpeggios with a click on half speed, so it's just on beat 1 and 3, (or beat 2&4 is good for practicing swing). That way you're having to use your internal clock more, and relying on the metronome less. You can also play your scales in different patterns, so maybe let the click play beat one, then you play the next 3 8ths notes, then rest for the click on beat 3 and so on, anything to break the pattern up and gently challenge yourself. Build stuff like this into your 10 min warm up everyday and you should see results!
I'll give it a go.
i've only tried the Android version, but it can be set to randomly drop beats,speed up and to have step increases. I'm going to try it out and see how it goes. So far the soundbrenner hasn't set my metronome world alight
As is hinted at in the quoted posts, once you start the metronome, spend a bar or four 'getting into it', mentally and physically, *without playing your guitar*.
I like the old approach of setting the metronome at half the tempo you want and visualising the clicks as snare beats on the 2 & 4...arguably a more musical usage and might make it less monotonous for you(?)
I have been knuckling down and It's got a bit better, scales in time with a metronome up to around 120/130ish and i'm fine. Where it all falls apart is rhythm chord progressions. Even simple stuff like D D U U D and I'm racing ahead. I subjected MrsSpev11 to one of the acoustic songs I've been learning and she said it was not bad (time wise, she rarely comments on quality so as not to offend ) as soon as I put the metronome on it all goes to crap.
More practice, less dicking about I think, just repetition until it sinks in.
I will get a looper though for no other reason than its a simple way to hear back what I just ruined.
