Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Eqd Speaker Cranker clone
Swapped V1 and V3 which has got the gain back, but still very quiet.
Half of what is now V3 is probably dead.
Too late now, but when you get a new valve to fix it, get *two* valves. Spares are a very good idea if you gig with a valve amp.
While you're at it, get a pair of power valves and at least two each of the fuses as well. (T2A and T500mA, 30mm usually unless the holders have been changed.)
And there's a Metro loop fitted, and waiting to be wired in.
NOS: https://www.ebay.co.uk/itm/RFT-Germany-ECC83-12AX7-Valve-Tube-New-Old-Stock-V27-1-/384583534876?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
Used (is it actually an RFT?): https://www.ebay.co.uk/itm/RFT-Germany-ECC83-12AX7-Valve-Tube-Used-Tested-V17-/185256460111?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
https://www.sonicake.com/products/twiggy-blues
Cheap, portable, plugs into PA.
R.
Yes - the internal construction is very distinctive, in particular the 'aerofoil' shape plates made from only one piece of metal folded round and with only one seam, rather than the standard construction with a seam each side - and the 'star' mica spacers with much larger points than most other valves.
You can often find bargains with RFTs since they were made very widely available to re-labellers, even by old-production valve standards. Many were sold under old Western European brands, when they were actually manufactured in East Germany - some of them even got branded with British MOD code numbers, when they were supposed to be the enemy during the Cold War...
