1. Bridge HB, splittable to SC with a push-push switch on one of the pots.
2. Bridge SC and Middle
3. Bridge SC and Neck
4. Middle and Neck
5. Neck
I’ve also found that the guitar has a decent amount of lively ‘ring’ to it when strummed unplugged, perhaps surprising for such a small body.
Bridge HB and neck single coil is a good combination on a HSS as well
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Out with the old pickups and electronics:
Fitted the new selector switch and the 2 single coil pickups:
All 3 Lace Sensors now fitted in place:
Quite a few conductors to trim and solder before I'm done:
I belatedly realised that the Lace wiring instructions recommend 250k pots and a 22nF tone cap, whereas I have used 500k pots and a 47nF tone cap. Consequently the volume control drops off pretty quickly and loses top end, and the tone control doesn't do much until the bottom 1/4 of its travel. I'm going to try a 1nF/150k treble bleed network for the volume pot, and a 250k tone pot and 22nF cap.
Thanks! I fitted the 1nF/150k treble bleed and it works a treat, the volume taper is much smoother and it retains treble when backed off. To fit it I had to pull the push-push pot all the way out of the cavity but it went back in fine because I had dressed the wires round the perimeter of the cavity as much as possible and left a bit of slack. The pickups are nice and quiet and definitely worth the outlay.
I find the vibrato to be so stiff in use that it's hardly worth the bother. I'll have to research whether it's possible to do anything about this.
But for now, a win.
I’ve ordered a 250k switched pot which should tame the top end. I’ve also ordered some numbered knobs with rubber grips as the original black metal knobs give no clue as to how they are set. When I fit the new switched pot I may re-wire it so that popping it out goes straight to bridge humbucker from whatever position you happen to be in. Or I may find I can’t be arsed…,
Unfortunately the singer referred to it as my ‘silly guitar’. Ah well.
That's what I was thinking- seriously tight fit there. I struggle enough when I have plenty of room!
LOL don't listen, that guitar is awesome (not sure how I missed your thread when you first posted it)
Awesome bass too @Strangefan
