I decided that before doing anything radical such as attacking the headstock or finishing the body I'd try and give it a setup as is to see what I had to work with. I popped on a set of D'Addario 10-42s and worked through the Haze Guitars Sketchy Setups issue for T-types. As a result, I got the guitar a lot more playable (which says more for the quality of Haze Guitars's guides than it does for my luthiery skills!)
The only turd in the fondue bowl is that I couldn't quite get the action as low as I'd like. It's liveable with, but the bigger problem is that the saddles are down hard against the bridge plate, which means that the little adjustment grub screws are sticking right up, making palm mutes spikier than they should be. As I understand it, I have the following options:
- Live with it
- Grind the little grubs screws down. This would fix the palm muting problem, but doesn't address that I'd like the action to be a little lower yet, would limit future higher action (such as if I wanted to set up for slide, or decided to develop a heavy right hand) and would require tools I don't have, such as a grinder of some sort.
- Aquire shorter screws. Again, this would fix the palm muting problem, but doesn't address that I'd like the action to be a little lower yet. I'm not convinced that the HB kit uses standard dimensioned parts, so getting drop-in replacements might be tricky.
- Shim the neck. I've read the Haze Guitars article on this, and I understand the principle. I'd look to buy a pre-made shim since my level of wood working skills aren't really up to precision machining ("within an inch or two" probably doesn't cut it for this job...)
Open to thoughts and advice on this!Harder shims can cause humps in extreme circumstances, but more likley just compress the wood slightly in the pocket.
You might still want to grind some screws down if they are all the same length, but definitely shim first
Instagram
Another question - if I shim the neck, is that likely to affect relief, needing further tweaks to the truss rod?
Instagram
1) Jam a bit of card in the neck pocket, as discussed above, and get the action nice.
2) Cut the headstock to shape. I’ve got a print-out template I’m going to use.
3) Finish it - likely with Annie Sloan chalk paint.
4) Sort out the wonkily aligned top E tuner
5) Replace the supplied scratchplate with a black one, partly for aesthetic reasons, and partly because the supplied one appears to be made out of cheese - it scratches as soon as you look at it.
