"The best bass amp is someone else's PA".
It's difficult to get a *properly* usable bass amp - if that has to include the speaker - that you can carry by yourself on public transport. I have an Ibanez Promethean combo - it's a 500W 1x10", just loud enough to hold its own against a moderately loud drummer, but even though I've replaced the speaker with a lighter neodymium one it's at the very upper end of what I would consider portable over any real distance without a car. It comes in a neat shoulder bag, and weighs 12Kg/25lb, but it's still a 30cm+ cube and quite awkward, especially if also carrying a bass even in a gig bag. I also recently tried a Markbass Micromark which was a *bit* smaller and lighter - although not that much really - but much less capable as an amp.
Even going for a separate head and cab isn't going to help much, no matter how tiny the head - and there are some truly ridiculously small ones now, in the 100-250W range - because the cab just can't be that small or light, the same sort of size as the Promethean is about the minimum.
The good news is that a decent preamp/multi-FX through the PA is a very valid alternative now, anything from a simple analogue amp emulator to a full digital processor can sound great and will literally fit in your gig bag pocket.
Like everyone else, I'd regard a bigger rig as better, but it is surprisingly good for its size and weight.
It's 160w, and is plenty loud enough for pub-size venues. It works with drums, keys, guitar and two horns without breaking into a sweat. Its semi-parametric eq is very sensitive, and takes a bit of care to dial in.
If your bandmates are all busy trying to 'cut through the mix,' then you might want to choose something else. Or find some musicians who actually listen to the rest of the band.
The PA will certainly have a better low end. As long as you can trust the monitoring.
e.g. On paper, the Fender Rumble 200 seems to qualify for Secret_Sam's definition of loud enough. In reality, the nominal 200w is only achieved when an extension cabinet is connected. On its own, the combo is only good for 125-130w.
I vaguely recall Tony Butler of Big Country saying in a music magazine interview that he chose bass amplification by multiplying whatever wattage the guitarists were using by four.
My approach is to have a 450w system and never need to use it anywhere near full power.
It solves the OP's problem in a very literal sense insofar as having a car won't help you carry it. You need a low-loader and a forklift.
On the other hand...
I had an SWR bass 350 and in a couple of decades only had to call on its full glory twice. The internet is full of people who complain that the Bass 350 isn't loud enough. God save their ears.
I like mine. Not sure I could carry it and a bass on a bus though.
I’ve gigged this set up and it works perfectly welll and is light enough to carry long distances. Get a cover for the cab!
I can't comment on their bass speakers, but am enjoying the Metro guitar one. And certainly very lightweight!
So yeah, decent preamp, DI, and a little bit of something on stage and you’re sorted - the little EBS combo just happens to be all three in a single easy one handed carry box, and I reckon if I ever play anywhere that needs more grunt on stage than it can provide when setup nice and close to me there’ll almost certainly be enough on-stage monitoring to fill the gap.
Which is not to say it isn’t good fun when I get to plug in to somebody else monster rig now and again… :-)
It's the "MB58R" series (snappy name!)
https://www.markbass.it/bass-amplifiers/ba-combos/?markbass=1&pa_series=mb58r&paged=1
Choice of 300W or 500W, some with 12s and others with 15s
The 300W 121P is only just over 10kg! I fancy one of those myself.
I also have a Markbass LM3 (500w) and two Traveler 102P’s. The cabs are really light too, but I wouldn’t try taking them on public transport.
Rob
[This space for rent]
All the best,
Pete
It all depends what sort of bands and types of gig the OP's mate is doing that would really help to make a recommendation. Also the gigs should be providing taxi fare some of the time.
