Hey everyone, hope your weekend went swell. I’m starting a stewmac kit build and thought I’d share. This is my first time here so bear with me. I stumbled upon tFB by the way of SOS forums, and have spent the last few months reading over guitar builds and have decided to take the plunge.
I have played guitars for years but never thought much of modding my own guitars or building them. I’ve never owned a Tele style guitar, just strats and LP’s, and thought that maybe I should just go about making one how I’d like it instead of shelling out the cash on an American made fender just yet.
I’ve done very minimal woodworking / soldering in my time but I’m looking forward to learning (and goofing up).
Sorry for the journal entry, I just wanted to let everyone know where I’m coming from. On to the build.
I ordered a “T Style” StewMac kit to start with. None of the components are fantastic of course, the tuners will be the first things to go.
reshaped the head stock today, first time using a jigsaw, I used a half round file to clean it up before sanding
https://i.imgur.com/ZSOP0kE.jpghttps://i.imgur.com/YArZ7uq.jpgI started sanding through the grades, and decided to use some simple boiled linseed oil for the finish. I’ve only one initial coat on, I’m going to attempt Wez’s wet sanding and final wax method sans the TruOil. I used BLO simply because it was immediately available. Depending on how this turns out I might try the TruOil in the future. I’ll approach this with more coats in a few days.
Hopefully by Christmas time I’ll be ready to start filing and crowning the frets.
My goal is to complete this build, attempt to recreate the body from a blank and refit all of this kit to it for trial purposes, and then go from there on learning how to accurately make a neck from wood.
If anyone has any recommendations regarding getting into building or thoughts on quality pickups or tuners I’d be thankful.
Thanks for all of the incredible information you all share here, take care!
I generally buy gotoh tuners and hardware by default.
Lots of pickups about, a broadcaster style set from Fender/Mojo/SD/Creamery possibly too is the default. 60's if you want twangier at the bridge or a modern SD/Oil City/Bareknuckle bridge pickup if you want fat and smooth.
Either way, tele bridges kill with a cranked tweed or AC.
Neck pickups are usually 'jazzy' as the brass or even nickel silver does kill highs a bit. For this reason many modders pop in a strat, p90, filtertron or goldfoil.
My personal preference is a 6 saddle barrel bridge for intonation (new blocky ones are ok but dont aways look right) but you might want 'that' brass 3 saddle look too. 4 way switching is fun and gives a nice fat option.
Rob was a regular at tdpri and I've had a set of his. Good stuff and he'll probably match a set nicely.
https://cavalierpickups.com/
Also please drill pilot holes for screws, dont try and just drive the screws in, they will break and that, is a disaster.
Looking good, thats a decent headstock shape
Thanks Paulnb, I feel pretty silly for not thinking of that, I forgot about having to drill holes for the machine screws still before I started the finishing. Luckily I’ve only put the one coat on, once I’m confident it’s dried I will assemble and drill my pilot holes where need be before I start the wet sanding step of the finish. Thanks for the call out!
Your Tele turned out beautiful, I’ll be pleased if I can get it in that same condition! After each coat I go back after 30 minutes and wipe of excess then again 30 minutes after that.
https://i.imgur.com/817ARMI.jpg
https://i.imgur.com/DWAH5nR.jpg
Problem #2: when the pickguard is probably set flush with the neck, it leaves an ugly gap between the control plate and guard. I don’t need much space to get it flush, but will probably need to route out a few more mm to push it into place. As @paulnb57 pointed out, I should have caught this before the finish. I will probably end up leaving the gap as a reminder of the best build sequence.
https://i.imgur.com/Y0ZS4gH.jpg
next steps will be dealing with the frets and fret board. Hopefully will have to start on that after the holiday. If anyone has any advice on what, or what not to do, I’d love some feedback, thanks!
Instagram
next I started on the electronics. I’ve never soldered for a guitar before, but have made electric drums with piezo pickups and 1/4 inch jacks. When I was a teenager buying cheap snare drums and cutting mattress foam to size and layering the piezo between layers of that combined with a mesh drum head allowed me to create drums that were standard size and fully electric. Something not available then at any price.
anyways, I happened upon SixStringSupplies’ video about tele wiring. Followed it as best as I could with a few adaptions. Tucked the cap under between the pots due to clearance issues in the cavity. Worked out well. Had a hell of a time getting my 60W iron to solder to the caps. I know it’s because I couldn’t find 60/40 anywhere where I live and had to use lead free. I will never attempt that again. Somehow I managed without any cold joints (I think). I had to do a constant cleaning and tinning to get any heat to transfer.
More importantly - how does it play and sound?
You can spend hours chasing a high/low spot up and down the board and across each fret, removing a minuscule amount of fret wire and having a huge impact on playability of the instrument.
Once you’ve got it sorted, the guitar can be set up just right, and you end up with a beautiful playing guitar.
Then you realise that you could never sell it because it plays so well, so you set off down the infinite rabbit holes of modding, upgrades and tweakery.
Enjoy!
Considering I don’t care for the neck finish or fret job, I’m going to have to redo all of that.
I’m going to undo most of the wiring to try to get a cleaner job done, and then I’ll have to copper tape/solder joint all of the cavities.
I feel like the finish needs a better sanding anyways. I will probably undo everything with the exception of the tuners, they’re functioning fine.
I'll sometimes go step-by-step when trying to work out the cause of a problem. So with your hum & sitar problems, try connecting each of your pickups, in turn, direct to the output jack. That minimises the amount of connections that you need, and so minimises the risk that one or other joints isn't quite right.
You don't even have to solder them in place - just use some crocodile clip wires to make temporary connections.
If that removes the problem, then add-in other parts of the wiring, testing each change as you go. it's one of those things that might take longer in the short-run, but saves a lot of time in the long run.
Sounds like you've got the perfect place (ie an inexpensive kit!) to try out all sorts of different techniques and build your skills as you turn it into a decent player. Better practising on that than something expensive
