https://www.axesrus.co.uk/Medium-Shaft-PushPush-Alpha-Pots-p/medpushpushalpha.htm
Or you can pay Megabucks
https://www.armstrongmusic.co.uk/electronics-c17/pots-c69/wd-music-500k-push-push-pot-with-us-specs-p4975
It's a pity as they're nice to use.
I think Axecaster has the Alpha ones too. One of them is metric and the other imperial... don't quote me on this as I may have it backwards, but I think the Axecaster ones are imperial and the Axesrus ones metric. I've used both and they're fine.
I suspect the Bourns ones are nicer, but they're more expensive. I think WD/Armstrong Music has them.
But the worst thing about them is that they’re very easy to break if someone doesn’t realise that you must not try to pull them up, or especially try to get the knob off, from the down position.
In good news though, I managed to strip the broken one down without the spring mechanism flying out so I now know exactly how it should fit in my other broken one
